Initial test results with Oriental FB Glossy and MIS VM Inks
2003-12-03 by Editor P.O.V. Image Service
I've just run initial tests with the MIS VM inka on some samples of
Oriental Graphica FB..
I'm going to wait for full drydown before making final statements..
However, I ran a 21 step wedge with the inkset and printed it with three
different paper settings in a 1270 using the standard EPSON driver:
Heavyweight Matte, Premium Glossy Photo Paper, &
Photo Quality Glossy Film. The driver was run at 1440 dpi with "high
speed" printing turned off - just as one would for standard VM prints on
EEM.
Surprisingly (at least to me), on initial inspection, there is no
visible difference in the resulting step wedges.. That would indicate a
high threshold for potential inkload on the paper.. Whether that has
resulted in a higher dMax on any of the wedges is still out with the jury..
There is also no visible bronzing in these wedges... However, there is
some ruboff of pigment in the darkest parts of the wedge.. I'll see if
drydown affects the latter..
I am impressed that the surface of the paper seems relatively (not
perfectly though) consistent between areas of high ink load and areas of
low ink load.. It does look like very much like a ferrotyped FB print to
me.. (although as others have noted, the tactile suppleness one expects
from a traditional FB print isn't there)
Once the wedges dry down fully, I'll likely have more to say on this..
Keith Krebs
"Just some guy," and caretaker of the Multiverse's largest EPSON printer
User Community (highly recommended by Vogon Poets and MegaDodo
Publications), at:
http://groups.yahoo.com/group/EPSON_Printers/
"For the rest of you out there, the secret is to bang the rocks together
guys"
CONFIDENTIALITY & COPYRIGHT NOTICE:
This e-mail message, including attachments and contents, is \ufffd Copyright,
Keith Krebs, 2001-2002, All Rights Reserved. It is expressly for the
sole use of the intended recipient and may contain confidential and
privileged information. Absent the express written authorization of the
author, any unauthorized review, use, disclosure, transfer, or
distribution is explicitly prohibited and taken at your own risk. If you
are not, or are unsure whether you are, the intended recipient, please
contact the sender immediately and destroy all copies of the original
message. Violations will be prosecuted to the FULL extent allowed under
applicable civil and criminal law. Imagery published or distributed in
violation of these conditions shall be subject to a $1500/image
liquidated damages charge, in addition to any applicable Copyright
violation penalties.
{ The P.O.V. Image Service Website is still at http://www.p-o-v-image.com/ }
