Heath,
>As far as I can recall, I'm using the 870 driver
>from Epson's website with the 1280 UT curves.
The 1280 curves will probably only work well with the 1280 (or equivalent
letter-size printer) driver. I believe some people with 1270s and UT inks
are getting good results by using the 1280 driver, which they just download
from the Epson website.
Have you tried the 870/1270 VM curves?
_________________________
>>>... UT inks in an Epson 870 (small version of 1270) ...
>>>As a sidebar, I haven't been able to use the stock Roark curves from
>>>the 1280 in this printer. Very abrupt transitions and not smooth at all.
>>Did you use the 1280 driver with it or the 1270 driver?
