RE: [Digital BW] MIS VMS vs. VM greys
2003-12-04 by Paul Roark
Mike,
>Could someone tell me if the grey and black inks in the MIS VMS
>inkset are the same as in the VM set?
The VMS black is the same as the VM black.  The VMS gray inks are not the
same; they are based on the FS-N inkset.  The VM grays are based on the
original MIS quads.
>In otherwords, if I needed a little VM-Hex-4-Y and I had some
>VMS-Hex-4-Y sitting on the shelf, could I substitute it??
No.
> Also the K??
The K you could use.
