MIS VM Color Spaces & Monitor Calibration
2003-12-06 by rbehr2001
Paul's workflow for my 1160 indicates I should work in the sRGB color
space, but what about the Grayscale color space? Should I create a
custom gray space for WYSIWYG like recommended for Piezography?
If I do that, I have the problem of compatibility between
systems/drivers. I have a lot of images made for printing in
Piezography in a custom greyspace. Since I'm now working with two
quadtone printers and ink systems, and since I will probably be
changing inks and systems over the years, maybe it would be best to
just settle on a standard greyspace and then use correction curves
for each system.
If a standard space is the answer, what should it be? And how should
the monitor be calibrated? Jon Cone is adamant that the space should
be gamma 1.8 and that the monitor should be calibrated to gamma 1.8.
I find that way too flat compared to my prints. What's everyone else
doing?
