PiezographyICC first impressions
2003-12-10 by James Haney
I got home last night at 10:00pm and found a box with my PiezographyICC software. Since I have an 1160 and didn't need to do anything other than install a couple of profiles I thought I would give it a try. I must say that my first impressions are very positive. First, the screen preview is, in fact, incredibly close to what I get printed out. Second, the very faint, but apparent microbanding I have always had is gone, replaced by an all but invisible dither pattern only discernable in certain tones and at high magnification. This is an incredible improvement. Third, I had to make very minor changes to my images. In general my old images are too light when printed without changes. Luckily, I work with unflattened adjustment layers in my images. So I just open the adjustment layer, make some minor tweaks and print. Fourth, it is great to be able to work in Photoshop while my image is printing. This will double my productivity. Fifth, I don't have a densitometer, but the max density definitely seems blacker. Sixth, the initial setup is a little confusing. It took me a while to figure out which profiles I needed. It seems like they could have come up with a better method of communicating this. There is a lot of reading to be done in the manual and a lot of settings to confirm and or change to get things working correctly. However, once set up, it is all pretty seamless and the new settings don't screw anything up too much. Seventh, it seems, after reading the manual, like people who are not using Photoshop are in for a bit more of a quest for the right settings than I experienced. But a careful reading of the manual should lead them in the right direction. This is only after a cursory look at three prints made last night, I am sure we will all be discovering the traits of the new system in the days to come. PiezographyICC Epson 1160 PT Selenium with Portfolio Black (carts) Hanemeuhle PhotoRag Mac OX 10.3 Photoshop 7 Previously using ImageExportBW (R9) James Haney
