Epson 4000 - MIS plans? Can we have a teaser....?
2003-12-15 by scrber
I just can't wait to see what the Epson 4000 will bring in terms of
specialist B&W inksets.
I am pretty sure Paul will already have been rubbing hands thinking
of wonderful ways to make the most of it's eight inks.
I had planned to get one and use IP with colour inks.  But being
honest with myself, I just don't print colour anymore, so whats the
point?
The thought of self aligning heads and auto nozzle cleans are enough
for me on their own!
Therefore, I wondered, does anyone have any ideas how this printer
could be properly ustilised and what kind of inksets we could
envisage?
I guess that first port of call is something like the UT2 set with
Photo and matt black installed, perhaps with an additional grey
position?
Bye bye 1290's.
Kind regards
Steve
RE: [Digital BW] Epson 4000 - MIS plans? Can we have a teaser....?
2003-12-15 by Paul Roark
Steve,
>of wonderful ways to make the most of its eight inks.
Well, actually the matte and photo blacks and the attributes you are
describing below are the main advantages I see.  The light K may be more of
a problem than benefit.  I'll take the Epson driver approach, so it's
another out-of-control ink.  So, it's basically going to be a UT-2 with a
light K that is probably tones slightly to neutralize it.  I'm afraid the
shadow tones for the neutral prints will be too warm otherwise.  (It's going
to take some experimenting to get it right.)
>position?
The UT-2 is now a two-toner (cool and sepia) setup.  I'll continue that for
the 2200 & 4000.
The sepia toner spot (yellow position), however, is really designed for
custom toning.  The sepia I use is just 8% y, 8% m and 84% UT-2 light
magenta.  (Magenta is the raw carbon ink position in UT-2.)  I suspect some
will want to not only mix different shades of sepia -- e.g., change the
ratios of the y & m -- but also mix their own toners.  The cold ink is so
cold (c - y = 0.14 at 50%) that it wouldn't take much of an additional cold
toner to make a cyanotype tone.  The old carbon/carbo prints seem to have
hues that are determined by the pigments that were used.  The yellow spot in
the UT-2 inkset can, similarly, be used to achieve any number of subtle (or
not to subtle) tones.  It's wide open, and since the inkset depends on the
Epson driver to do most of the cross-overs, the curves are much easier to
deal with than the older partitioned curves.
Re: Epson 4000 - MIS plans? Can we have a teaser....?
Thanks for the feedback Paul, I'm curious on a couple of things - if
the new printer has a smaller dot size, is it not theoretically
possible to run a grey quadtone inkset next to a four colour inkset
and still be able to run perfectly good prints from both.  I know
this is dedicated RIP stuff - but is it feasible?
Secondly, I find significant shifts in colour due to different
papers types with my UT inks at the moment.  For example, my Imajet
matt has a slightly green tinge, the somerset velvet slightly
magenta and PR/EAM neutral.  If the UT2 for the 4000 or whatever has
greater toning range, how can it be 'easier' to control the shifts
and tones than today with a relatively narrow tone set?
Jumping the gun entirely, any idea how quickly MIS / yourself will
respond to the 4000 release?  We are due the printer here (UK) in
January according to Epson and my local dealer.
Steve
<paul.roark@v...> wrote:
> Steve,
of
thinking
are
be more of
it's
with a
afraid the
(It's going
enough
with
> >position?
that for
> the 2200 & 4000.
designed for
light
suspect some
change the
ink is so
additional cold
to have
yellow spot in
subtle (or
depends on the
easier to
> Paul
> www.PaulRoark.com
RE: [Digital BW] Re: Epson 4000 - MIS plans? Can we have a teaser....?
Steve,
>... is it not theoretically
Yes, I think it is feasible.  Until Bowhaus crashed, I thought I'd probably
use that system.  However, being a PC user, I know of no easy, inexpensive
RIP that can do it.
Yes, papers print differently.  I find some of the acid-free matte papers
print with cold shadows, for example.  I like to neutralize these.
>  For example, my Imajet matt has a slightly green tinge
I'm not familiar with it.
I find the UT inkset verges on too magenta in the shadows with some papers.
The tones have been compromises among the papers that I believe are most
often used.  A full color inkset with a full grayscale inkset is the
ultimate, but it may be hard to control accurately without a very good RIP.
(An MIS customer is going to try to set up a 7000 -- with RIP, I assume --
with a black, 2 grays, and 3 colors.  I'm skeptical that the 7000 is up to
the job.)
>the somerset velvet slightly magenta and PR/EAM neutral.
You can see how I weighed the papers for the balancing -- EEM for drafts, PR
for final cotton prints.  UltraSmooth was also up there in importance.
The Epson driver's built-in cross-overs handle a lot of the "heavy lifting."
There is no very-light gray ink.  (It's just not needed on modern, small &
variable-dot hextones.)  Also, there actually is no cold toner.  It's a full
cold-tone inkset -- dark and light grays are all that is needed now.  The
C82 matches the 2200 Image Print quality with only a single gray ink
density.  Image Print runs the light black all the way into the highlights
when in B&W mode.
So, the UT-2 inkset includes a cold inkset (dark and light cold grays -- in
the cyan ink positions), a raw carbon inkset (dark and light un-toned grays
-- in the magenta ink positions) and, in the yellow position, a sepia
toner/light ink (which is 84% the UT-2 light-magenta-position ink).
The UT-2 inks are close to the densities that the driver and papers were
designed for.  As such, they print nicely with no controls.
When RGB curves are used, they can be very detailed, but very simple ones
work amazingly well.  (That is one reason the sliders work to control the
inks.)  As an example, I have an RGB neutral curve where the main cyan (cold
inkset) and magenta (carbon warm inkset) curves start and end at (0,0) and
(255, 255).  Then in the interior, there are just 3 points -- one each at
50%, 25% and 75%.  So, one can control the midtone, highlight and shadow
relative tones very easily with simple up or down moves of these few points.
This is easy enough that I think many will be comfortable getting into it to
profile to their liking.
The un-wanted inks are easy enough to cut off.  I tend to just drop the
curves from 75%.  They mostly become the black ink control curves,
contributing little ink to the mix.
The yellow position is really very open.  I use if for the sepia toner.
However, it can be any custom toner or even a light gray ink.
I think it would be easier for me to port the inkset to the 2200 first.
There may need to be changes made for these printers, but I expect the 2200
and 4000 to be very close.  So, I'll probably borrow a 2200 first to set it
up.  Then, (assuming I'm successful), I'll order the 4000.  I hope to do the
2200 project in January.
_____________________________________
> Steve,
of
thinking
are
be more of
it's
with a
afraid the
(It's going
enough
with
> >position?
that for
> the 2200 & 4000.
designed for
light
suspect some
change the
ink is so
additional cold
to have
yellow spot in
subtle (or
depends on the
easier to
> Paul
> www.PaulRoark.com
they are often being updated.
page.
them short.
membership without notice.
the membership.
Re: Epson 4000 - MIS plans? + 'glossyeriser'
2003-12-16 by scrber
papers
papers.
most
good RIP.
assume --
is up to
> the job.)
drafts, PR
importance.
Exactly, and totally agree, a great way to meet the paper needs of
both.  Great shame that Epson don't support Ultrasmooth here in the
UK with anything other than wide format rolls.  I hope this may
change with at least 17" cut sheet for the 4000.
were
simple ones
control the
cyan (cold
(0,0) and
each at
shadow
few points.
into it to
That does sound like a dream system.  Perhaps one the OEMS will have
their eye on.  If common drivers work, the OEMs could just use ICC
profiles to support B&W inksets I guess.
I really look forward to that tunability - I miss it a little, I
daren't mess with your curves again (it's a little like witchcraft I
think - In past days you'd have been dunked in the river  ;-)  )
first.
the 2200
to set it
to do the
Excellent news!  I assume it's a case of working out the driver
differences and scratching the head until you come up with a way to
ustilise position 8.  I may well join the wait list / beta list in
anticipation.  Just out of curiosity - MIS support these large format
printers with re-filled carts or what?
Are these inksets going to be good for semi-matt / luster?  I cannot
remember reading if you had many any 'bronzing' comments on the UT2
set yet.
One final thought...  What about that 'glosseriser' or whatever the
heck they call it.  The clear 'laquer' layer that comes with the new
ultraglossy inkset.
Could this not be used for the spare ink position in the 4000 and
leave us in the wonderful position where we don't have to spray or
worry about bronzing.  Thinking out loud though, how do you control
it?  Not with curves thats for sure.  Still depends on whether they
will support the ultraglossy inkset and provide the relavent driver
interface I guess - still, a possibility right?
Thanks again for the overview and good luck.
Steve
Re: [Digital BW] Re: Epson 4000 - MIS plans? Can we have a teaser....?
2003-12-16 by Editor P.O.V. Image Service
>the job.)
I dunno. That 4 picoliter drop size of the 7000 would argue against
it... Especially if you want smooth skintone transitions for color work..
Keith Krebs
"Just some guy," caretaker of the Multiverse's largest EPSON printer
User Community (highly recommended by Vogon Poets and MegaDodo
Publications), at:
http://groups.yahoo.com/group/EPSON_Printers/
and  the Multiverse's largest Canon printer User  Community at:
http://groups.yahoo.com/group/Canon-printers
"For the rest of you out there, the secret is to bang the rocks together
guys"
Re: [Digital BW] Re: Epson 4000 - MIS plans? + 'glossyeriser'
>ultraglossy inkset.
It's driver controlled and user overridable to some extent..
http://www.photo-i.co.uk/News/Nov03/Epsondata.htm
Now, it could be conceivably used with a RIP in the 4000 or:
keep in mind that EPSON is already going to have a dual channel CMYK
version of the printer for sale as well.. That conceivably requires a
different driver,
It's not out of the round of possibility therefore to foresee EPSON
releasing a driver or version of the 4000 that could use the Hi Gloss UC
inks,,
However, the gloss optimizer works inversely to the way you envision
it..  It gets laid down on areas of little ink coverage to increase
gloss..  Since bronzing is the result of heavy ink loads, not low ink
loads, it likely would not be of much help (unless we want to bronze the
entire image).. Although, who knows?
Keith Krebs
Publications), at:
guys"
Re: Epson 4000 - MIS plans? + glossyeriser
2003-12-16 by stephen.bate@mubea.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Editor P.O.V.
Image Service" <editor@p...> wrote:
new
> >ultraglossy inkset.
control
they
driver
CMYK
a
> different driver,
Gloss UC
> inks,,
envision
ink
bronze the
Mmmm.  I understood slightly differently.  That yes, it gets laid
down to avoid bronzing and that there were three options to its
application (all this is relavent to the R800 mind you.
1. Apply to areas of low ink coverage (as you mention)
2. Apply to entire image area (leaving borders uncoated)
3. Apply to entire page area.
Now if someone wanted to make a robust inkjet coating that would work
in the volumes applied by the epson driver (obviously nothing like
the 3 coats of laquer guard we were talking about in earlier threads)
this would be a bonus surely?
Steve
> Keith Krebs
printer
> Publications), at:
together
> guys"
and the 4000 is only 3.5 if I recall - still pretty big by todays
standards.  You could pump paint through that.
assume --
is up to
> >the job.)
work..
> Keith Krebs
printer
> Publications), at:
together
> guys"
RE: [Digital BW] Re: Epson 4000 - MIS plans? + 'glossyeriser'
2003-12-16 by Paul Roark
Steve,
>>driver and papers were designed for.  As such, they
>>print nicely with no controls.  ...
>>... I'll probably borrow a 2200 first to set it
>>I hope to do the 2200 project in January.
>... position 8.
I think the system will remain close to the hextone printers but with a
Photo K and Matte K (Eboni probably).  Epson controls don't allow much more
control.
>... MIS support these large format printers with re-filled carts or what?
I don't know.  They'll probably do whatever the market wants in enough
quantity to be profitable.
>set yet.
I see the 4000's ability to have both matte and photo blacks as a big plus.
That is one reason I'm exploring the barrier/RC papers.  With the sprays
like PremierArt Print Shield and Lyson Print Guard, the bronzing can be
controlled to the point of being quite acceptable.  I especially like the
Epson Premium Semi-gloss and Semi-matte papers.  See those threads.
>the new ultraglossy inkset. ...
The new R800 will lay down clear glossy balls ("blanks"?) that I assume are
the same as the clear coating on their pigments -- but without a pigment
inside.  This is said to help with bronzing.  However, I don't see any way
to control this material with the controls that are available with the
normal Photoshop-Epson driver controls.  The Print Shield sprays probably do
as good or better job, while protecting the print, probably, better.  The
Epson approach will, of course, be easier.
>work..
>you mean 10 picolitres for the 7000.  7600 is 4 picolitres.
oooPS!  Actually, that should have been 8 I think..
Exactly, thanks for correcting it.. And even 4 would be rough, 8 is a
HUGE stretch..
Keith Krebs
Publications), at:
guys"
>work..
>Q.
In addition to the 7000 having an 8 picoliter size it doesn't even have
Variable drop size..  I just don't see it delivering great photo quality
Color & B&W images  with the setup Paul mentioned.
Keith Krebs
Publications), at:
guys"
>set yet.
I believe the cartridge design is the same as the 7600..
That should give you some guess to an answer.
Keith Krebs
Publications), at:
guys"
Paul,
You should probably check the documentation from EPSON on this..
To quote them:
"More specifically the glossiness in very light or no colour areas may
occasionally appear less glossy/flat and therefore create an uneven
gloss finish. By placing Gloss Optimizer in the areas of low ink duty, a
uniform gloss finish is achieved."
You can see the actual data sheet in HTML form at:
Since bronzing typically appears in high ink usage area, the way the
gloss optimizer works would seem to be the very opposite of  laying a
coating over areas of heavy ink coverage, as on those areas the gloss
optimizer lays down NO particles..
The use of the gloss optimizer is simply because the new EPSON HG UCs
have a glossy character of their own.. That glossy character should
reduce some of the bronzing.. However, it brings its own new issue of
low gloss in areas of low ink duty.   Then, the gloss optimizer is laid
down on low ink areas of the image  or on both those areas AND blank
areas of the page to achieve either:
a)   a uniform gloss across the image area
b)   a uniform gloss across the entire media
By the way.. Mac OS X users should note this:  option 'a' is not
available under OS X.. only option 'b' is..
Keith Krebs
Publications), at:
guys"
