Print Shield on matte paper: density change, scuff resistance, and fading--Part #1
2003-12-16 by Jon
Hi group, I just received my first can of Print Shield http://www.premierimagingproducts.com/ and am testing it out right now. I printed out two 21-step wedges on a sheet of EEM letting it cure for 24+ hours. I then sprayed one wedge (three coats, rotating print 90 degrees between coats) and let it dry 24 hours. I'm using MIS Ultratone carts in a 2200 with an IJC/OPM profile. So far under incandescent light the two wedges look similar--I can't detect any visual difference. I'm getting the following density readings: Before applying Print Shield 0% step : 0.05* 1% step : 0.08 5% step : 0.15 25% step: 0.50 50% step: 1.04 75% step: 1.28 95% step: 1.57 99% step: 1.64 100% step: 1.66 After applying Print Shield 0% step : 0.07* 1% step : 0.09 5% step : 0.18 25% step: 0.55 50% step: 1.08 75% step: 1.32 95% step: 1.57 99% step: 1.63 100% step: 1.65 *paper white, no ink (My densitometer holds +/- .01 and I measured both step wedges before coating the one) Seems like at the highest ink densities, the spray doesn't increase density--it lowers it a bit. At the lowest ink densities, the spray increases density a bit. You get the most increase in density in the mid tones. I'm wondering how much of these differences are caused by different absorption rates or my spraying technique... I'm going to let the coating dry a couple of days and read it again to check for density changes, then I'm going to try to scuff and scratch the surface, and then leave it out in the sun for awhile to look for fading. How about list members using coating rods and other coating materials? What kind of density changes are you getting? Is the surface of your coated paper harder to damage? Any yellowing or fading? Jon
