Re: poor man's densitometer?
2003-12-18 by bruce greene
thanks for the link Martin. I may give this a try. But I don't think that my scanner is up to the task as it seems to clip the highlights slightly. -bruce On Thursday, December 18, 2003, at 03:25 AM, DigitalBlackandWhiteThePrint@yahoogroups.com wrote:
> Bruce, > > Another idea for you. Go to: > > http://www.stouffer.net/Productlist.htm > > Contact Stouffer and purchase their 37-step calibrated reflection > guide, > R3705-1/2C fro $29.60. This will come with density readings for each > step. > If you have any kind of a flatbed scanner you can then scan this > calibrated > target along with the 100-step wedge you print with your printer. From > the > scan in Photoshop you can use the eyedropper tool to measure K values. > > With a bit of math you can use the scanned values and the calibrated > values > to calculate the density values of the step wedge you printed. > > Martin Wesley > www.carolynfrayn.com/Guests/MartinWesley/pages/MW_01.html > www.borderless-photos.de/guests.html
