Re: [Digital BW] Re: Epson's RIP for the 2200
2003-12-18 by Peter Palmieri
Sandy--thanks for the reminder and the message number.
I have made copies of your workflow and the short thread about using the Epson RIP. I am using WIN XP so it shouldn't be too difficult to compare your workflow to the one I had been using. Have you tweaked the workflow at all since you posted it last February? Are you still using it?
I recently bought some Hot Press Fine Art paper from Inkjetart which has caused me to again think about printing B&W's with the 2200. But, it is expensive paper to be doing trial after trial...
Peter
  > Has anyone used the Epson RIP with any success?
  I've gotten great results with the RIP on the 2200. Prints come out
  warm-neutral. You might check out message #26960 for my detailed
  workflow with the RIP on the 2200. Workflow is for PC, I'm not
  familiar with the Mac but maybe you could adapt. Good luck.
2003-12-18 by Scott Graham
Expensive?  I hope you are printing many small tests on each sheet?  I do about 3x4's
or so to see if the tones are right etc.
and bear in mind that each paper reacts differently to the inks, giving different
"colors"and different black densities.  I suggest that you try Epson Velvet if you want
neutral tones and good blacks.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Peter Palmieri"
> Peter
>   From: sanfo2003
