Re: [Digital BW] PhotoShop CS vs. PhotoShop 7 - some hard data
2003-12-29 by Jack M Kucy
I am stunned by the time your machine needs to start PS-CS. My laptop Win XP - 2.4GHz, 1GB RAM, with the 3.8GB partition for a scratch disk loads the PS-CS in 28 sec. I have just checked it 3 times, rebooting the machine and starting from scratch. My old station Win2K - 550MHz, 1GB RAM, with the 15GB partition for a scratch disk loads the PS-CS long - say very long for me - 1min 27 sec. I have not too many plugins, but the usual Andromeda, Genuine Fractals, IR and so. I could never thought that the machine with double processor drags it's feet that much. --- If I am frustrated by the slow start of the PS-CS... Wow... Jack Editor P.O.V. Image Service wrote: > This was originally prepared by me for the EPSON list I caretake, but I > though people here might like to see it. > > > Versions of PShop earlier than CS only allowed the option of outputting > in 8 bit to the driver. However, you could still print a 16 bit image.. > PhotoShop simply did the conversion to 8 bit, before handing the data to > the driver.. Now, PShop CS CAN output 16 bits to the driver, but only > AFAIK only RIPS can handle the 16 bit data directly, not stock EPSON or > Canon drivers (which are restricted to 8 bit input) > > Except in the rarest of cases, like a quad B&W inkset on the rare image > where 8 bit data sent to a RIP caused some visible banding, > posterization, or other artifacting, I'd say this is not a big deal.. > After all most professional RIPS don't need to take data from > PhotoShop anyway, and can directly print from a save 16 bit TIFF, etc.. > > Beyond a RIP as mentioned above, I see no reason to wait even longer for > prints, just to say I used 16 bit.. > > > Some data for my dual CPU WinTel system with 2gB RAM (1.5 gB used for > the system and 512mB of RAM set aside as the first scratch disk - > contiguous disk space on 7200 RPM drives for the rest of the scratch > space):.. All settings and plugins on both versions of PShop are the > same.. (One important thing, these operations were done in the order > listed, you'll see that PhotoShop doesn't like to return RAM.. That's > one reason I say it badly needs some new memory management instead of > feature upgrades. Work with a really big image and you are better off > closing PhotoShop and restarting it if you don't plan on continuing > using images that large, as the rest of your system will still be taking > the RAM hit for the largest image.) > > (RAM usage figures are for the PEAK RAM usage during the operation) > > Photoshop 7 > > To Load/Start-up the program: 40 seconds - PhotoShop using 65 mB of RAM > and a 48 mB Scratch file > > To load a 44mB PSD file: 8 seconds - PhotoShop using 153 mB of RAM and > a 217 mB Scratch file > > To load a 64mB TIFF file: 9 seconds - PhotoShop using 222 mB of RAM > and a 233 mB Scratch file > > Unsharp Mask Applied to 8 BIT 64 mB TIFF: 3 seconds - PhotoShop using > 227 mB of RAM and a 233 mB Scratch file > > Unsharp Mask Applied to 16 BIT 128mB TIFF (16 bit version of preceding 8 > BIT 64 mB TIFF): 16 seconds - PhotoShop using 358 mB of RAM and a 358 > mB Scratch file > > Conversion from 64 mB 8 BIT file to 128 mB 16 BIT file: 3 seconds - > PhotoShop using 363 mB of RAM and a 299 mB Scratch file > > Extensis Intellihance Pro 4 plugin running on the 64mB 8 BIT file: 29 > seconds - PhotoShop using 437 mB of RAM and 300 mB Scratch File > > At no point did PS 7 exceed the RAMDISK Scratch file capacity. > > > > PhotoShop CS > > To Load/Start-up the program: 4 min 16 seconds (my recommendation, GO > GET COFFEE! - actually you could probably grind it from beans and brew > it.. most of this time was spent scanning plugins) - PhotoShop using > 104 mB of RAM, a 523 mB Scratch file on the RAM DISK, and 1.4 gB of > contiguous Hard Drive Scratch Space.. > > To load a 44mB PSD file: 2 seconds - PhotoShop using 238 mB of RAM a > 523 mB Scratch file on the RAM DISK, and 1.6 gB of contiguous Hard > Drive Scratch Space.. > > To load a 64mB TIFF file: 3 seconds - PhotoShop using 217 mB of RAM a > 523 mB Scratch file on the RAM DISK, and 1.5 gB of contiguous Hard > Drive Scratch Space.. (I'm surprised, but it actually gave back some RAM!) > > Unsharp Mask Applied to 8 BIT 64 mB TIFF: 5 seconds - PhotoShop using > 309 mB of RAM, a 523 mB Scratch file on the RAM DISK, and 1.6 gB of > contiguous Hard Drive Scratch Space.. > > Unsharp Mask Applied to 16 BIT 128mB TIFF (16 bit version of preceding 8 > BIT 64 mB TIFF): 12 seconds - PhotoShop using 430 mB of RAM, a 523 mB > Scratch file on the RAM DISK, and 1.8 gB of contiguous Hard Drive > Scratch Space.. > > Conversion from 64 mB 8 BIT file to 128 mB 16 BIT file: 3 seconds > - PhotoShop using 405 mB of RAM, a 523 mB Scratch file on the RAM > DISK, and 1.7 gB of contiguous Hard Drive Scratch Space.. > > Extensis Intellihance Pro 4 plugin running on the 64mB 8 BIT file: 27 > seconds - PhotoShop using 637 mB of RAM, a 523 mB Scratch file on the > RAM DISK, and 1.9 gB of contiguous Hard Drive Scratch Space.. > > Preliminary thoughts.. Ok, you can see incremental increases in speed of > some operations.. BUT, the hit to the rest of the system is an order of > magnitude higher.. That means I would be more likely to want to quit > PShop CS to use other applications. Unfortunately, the extended load > time mitigates against choosing to do that.. > > Whether this upgrade is worth it, is up to the individual user.. > > > > Keith Krebs > > "Just some guy," caretaker of the Multiverse's largest EPSON printer > User Community (highly recommended by Vogon Poets and MegaDodo > Publications), at: > http://groups.yahoo.com/group/EPSON_Printers/ > and the Multiverse's largest Canon printer User Community at: > http://groups.yahoo.com/group/Canon-printers > "For the rest of you out there, the secret is to bang the rocks together > guys" > > > > > > > > > > > > > > Please visit the Group Homepage to check the Files, and other > resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish > to unsubscribe, please edit your Membership preferences by visiting > this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages to > keep them short. > - Good manners are required at all time. No personal attacks or > flames. Hostile, aggressive or argumentative users may be removed from > the membership without notice. > - Keep your posts and threads related to the group topic of digital > B&W printing. Users who persistently make off-topic posts may be > removed from the membership. > - By posting on this forum you agree to abide by the group rules and > guidelines, and to abide by the actions and decisions of the group > Owner and Moderators. See Group Topic, Rules and Guidelines in the > Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER > AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE > LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE > LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT > YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), > RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, > THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF > YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD > PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER > MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. > > > > Yahoo! Groups Sponsor > ADVERTISEMENT > click here > <http://rd.yahoo.com/SIG=12c2192tb/M=266841.4316200.5507732.1261774/D=egroupweb/S=1705019182:HM/EXP=1072764029/A=1911856/R=0/*http://www.lifescapeinc.com/picasa/landing.php?capid=222&caId=1985> > > > > ------------------------------------------------------------------------ > Yahoo! Groups Links > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/ > * To unsubscribe from this group, send an email to: > DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com > <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsubscribe> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > -- _________________________________________________ Jack M Kucy JMK Gallery (www.jmk-gallery.com) 917-991-2096 jmk@... Member of ASMP (www.asmp.org) _________________________________________________ ...a riveder le stelle [Non-text portions of this message have been removed]
