RE: [Digital BW] scanning and image size
2004-01-02 by ellery
I would suggest scan in at the maximum optical resolution which in this case
is 4000dpi. For print purposes you would need a sent to printer file of
pixel dimension say 270 to 300 dpi multiple the length or breath in inches.
Despite what has been said in this and other forums there is a difference in
print quality when my printing files hit say 450dpi  - from output on an
Epson EX (the printing time automatically become much longer).
Suggest you scan and save that file as the original master and do all work
from copies of that - preserve the master unchange at all costs. Lasersoft
AI should help you navigate thru the scaning maze with a lot more ease that
if you had to do it all manually for a newbie.
Work in PhotoShop and when you are done you can either use the resize the
image to either restrict the image to the print size (with the resample off)
and use what ever dpi is there. Or you could set the dpi to say 300 and use
resample on and set size to 11 x14 inches.  Question is would you want to
print in RGB or as a greyscale file - answer much depends on your tastes and
view light conditions.
  From: Joseph Robinson [mailto:joseph@hintonrobinson.com]
  Sent: Saturday, January 03, 2004 12:55 PM
  Subject: [Digital BW] scanning and image size
  I'm new to the forum and have just started scanning some of my 35mm
  black and white images (taken on Kodak T400CN).  I like to print
  final results at 11" x 14".  The images so far show
  some "posterization" in them.  I'm not sure of the solution, but I
  think that part of my problem could be in scanning...
  Do people generally scan the images at the highest resolution the
  scanner supports with the dimensions of the image the size of the
  negative?  Or is it better to scan at an "appropriate" resolution
  and have the image dimensions be 11" x 14"?
  I've been using the latter approach, scanning at 650dpi, setting the
  image size at 11" x 14" and printing at 1440 dpi.
  I hope this isn't too silly of a question and I've given enough
  information for a response...
  (Technical details: Microtek ArtixScan 4000t scanner, LaserSoft
  Silverfast SE software, Epson 2200 printer.)
  Joseph
they are often being updated.
page.
them short.
membership without notice.
the membership.
Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
  Yahoo! Groups Links
2004-01-03 by Joseph Robinson
Joseph
2004-01-03 by Paul D. DeRocco
> From: Joseph Robinson [mailto:joseph@...]
Forget about inches, except when it's time to print. Scan at the natural
resolution of the scanner, which I believe is 4000ppi. (That's not a huge
number of pixels when the piece of film is only 1x1.5") Also, with the 2200
you should print at 2880, to avoid microbanding in the print.
Re: [Digital BW] scanning and image size
2004-01-03 by Val Brunell
Joseph:  Regarding posterization...I believe the advice you are
getting regarding scanning at 4000 dpi at the input size is right.
Do your major tonal adjustments in 16-bit only.  When upsizing to
11x14, do so in small increments (maybe 2-3 inches at a time.) It
only takes a minute to upsize in 5-6 increments using this method).
Finally, go easy on your sharpening.  Hope this helps...Val
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ellery"
this case
file of
in inches.
difference in
on an
all work
Lasersoft
ease that
resize the
resample off)
300 and use
want to
tastes and
>   -----Original Message-----
>   From: Joseph Robinson [mailto:joseph@h...]
>   Hi,
35mm
I
>   Joseph
resources as
wish to
this same
> page.
messages to keep
> them short.
flames.
digital B&W
removed from
> the membership.
and
Owner and
> Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
THE PRINT
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
>   Yahoo! Groups Links
of Service.
Re: scanning and image size
2004-01-03 by sceptre12345
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Val Brunell"
method).
Val,
Why would one to upsize to 11x14, in increments yet, a 35mm negative
scanned at 4000dpi ?
In Photoshop, select Image Size, uncheck resample image and enter 11
for Height, if the image is horizontal. You have more than enough
resolution so that upsizing is not necessary.
Andre
Re: [Digital BW] Re: scanning and image size
2004-01-03 by Wendel White
Here is where I approach scanning differently. Andre's method is correct,
but I like to save the steps. I set the "output" size and resolution to the
maximum useful settings in my scanning software (assuming that it does not
exceed the hardware resolution of the scanner.) In my setup that would be
11" x 14" at 240ppi. There is a lot of discussion about the maximum useful
ppi (which I think varies based on the printing system, paper and print
size.) My goal is to minimize or eliminate any image resizing (except with
resample unchecked as Andre mentioned) to prevent any damage to the image
caused by interpolation.
Wendel
> method).
> Val,
> Cheers,
> Andre
2004-01-04 by Val Brunell
Andre...It has been my experience that upsizing by a large amount in
one fell swoop can cause image degragation by way of artifacts.
Upsizing in smaller increments minimizes this potential...Val
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sceptre12345"
right.
to
It
> method).
> Val,
negative
11
> Cheers,
> Andre
2004-01-04 by Wendel White
Val;
I think you have missed the crucial point in Andre's message, "uncheck"
resample means that the file is resized but not resampled - there is no
change to the pixels at all.
Wendel
2004-01-04 by Joseph Robinson
Thanks to everyone for the advice.
I will scan at the original negative size at 4000 ppi.  It sounds
like I should be able to change the image size in Photoshop just
before printing.  At that time, do I set the ppi to 300 or so, and
resize to 11" x 14" with no resampling?  I assume that this is
better than specifying the width as 11" in the print dialog.
Is that correct?
Joseph
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D.
35mm
I
natural
a huge
the 2200
> Paul                mailto:pderocco@i...
2004-01-04 by sceptre12345
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Joseph
> Is that correct?
Set the print size to the desired width and height in Photoshop.
Unless you want to scale the image with unconstrained proportions,
you do not have to resample the image.
Your images will benefit by using as much resolution as you can scan.
Images print with clarity starting at 240ppi. But 360ppi or more is
even better as, there will be  increase in detail if you can acquire
your images at higher resolution.
In other words, scans at the highest resolution, set your print size
in Photoshop, do not resample and let the PPI fall where it may. As
long as you're at 240PPI or more, you should be doing fine.
Andre
2004-01-05 by Paul D. DeRocco
Before you try any resampling, just specify the inches and let the driver do
the resampling automatically . That almost always works fine. Explicit
resampling is occasionally useful if you have an unusual image that produces
moire, but the solution is to resample to some integral subdivision of the
printer's natural resolution, which for Epson is 720. Resampling is also
useful if you just don't have enough pixels--certain algorithms can reduce
pixelation--but that's not going to be a problem if you sample at 4000ppi.
