Inconsistant nozzle checks / losing my sanity
2004-01-07 by Ranyart
I am getting inconsistant nozzle checks on a 1280 epson.  I print one
nozzle check, and I might have one small gap in the black position.
I re-clean, then, a small gap in a grey section that printed
perfectly on the previous nozzle check.  Very frustating.  If I
*ever* get a perfect nozzle check, I can almost be sure that the next
nozzle check or print job will have some screwed up nozzle positions.
Very frustrating.
I have had severe clogging problems the whole year and a half I have
had this printer.  First with Piezo inks, then, with Paul's new UT
inks.  I am at my wits end.
I have tried:
paper towel windex trick.
removing cartridges and inject windex via syringe trick.
coating rest pad with windex trick.
clean a few times, let rest a while, try again trick.
clean a few times, let sit overnight, try again trick.
I have no more tricks left.  I am ready to chuck this thing in the
dumpster.  I would pay for a new printer (again) to get a decent
print, but I have no assurances that anything I buy will be any
better than what I have.
I am now at the point of trying any drastic measure, as a last
restore.  I am willing to listen to anything.  Please post any
suggestions that will help me before I lose any last little thread of
sanity I have left.
Re: Inconsistant nozzle checks / losing my sanity
2004-01-07 by bwinkjet
I have had the same problems that you outline over the same period
of time using the 1280 with UC inks.  I finally gave up, cleaned up
using windex, wet towels, cleaning carts. and purges.  I then
reinstalled Epson OEM dye inks and the printer works well with
little or no problems with nozzle checks.  I bought a 2200 and Image
print and sure am not as frustrated as I was.  Just a lot poorer.
          --- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "Ranyart"
one
position.
next
positions.
> Very frustrating.
have
> I have tried:
of
> sanity I have left.
> Thanks,
Re: [Digital BW] Inconsistant nozzle checks / losing my sanity
2004-01-07 by D. Hill
First of all, don't give up.
Second, if you chuck the printer, chuck it this way...
> this thing in the
> get a decent
> will be any
My question is what is the final purpose (gallery,
prints for family, business) for your images, as well
as the final sizes.  If the printer is not working for
you, I will not be the one to advise pumping more
money into that pit.
Most WalMart stores have Fuji Frontiers these days,
and they give excellent greyscale results - the one
issue is prints can't be larger than 8x12 in most
areas.  Perfect prints with little investment - as
well as archivally stable (whatever that means).
Another bonus is that with a good profile of the
specific machine you are using, you can do excellent
duotone colorings/tonings.
If perfect tonality is your final image requirement, I
would highly suggest using a black only method for
printing.  You only have to clear up the black
nozzles, and with a pretty easy workflow - you will
get great images.
If a completely smooth or "grain free" image is your
intended purpose, you would not be completely content
with BO and are better off with UT2 or the
Piezography/R9 driver.  This still leaves you with the
problem of a good nozzle check.  It seems you are
doing everything you can - I don't really have any
alternative suggestions.
> as a last
> Please post any
> little thread of
> sanity I have left.
Well, other than the Fuji Frontier prints, and
printing black only, my last "drastic" suggestion if
you can't deal with the 1280 is this.  Sell it on ebay
and purchase one of the HP printers that use the new
grey position inks.  Last time I checked, the lesser
model that uses that cartridge (57?) is only about
$150.  The prints have a Kodak Polycontrast III RC
look with the familiar bromide green cast, but they
look fantastic for being an inkjet.  As the inks are
not a third party product, you may not have clogging
issues and you can print glossy.  Another bonus is
that carts are available at most local office supply
stores.  The downside is that you are stuck with a
letter size printer.
If all else fails, send your image files to west coast
imaging for output and concentrate on shooting and
editing.
Just a few thoughts,
Don
Do you Yahoo!?
Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes
http://hotjobs.sweepstakes.yahoo.com/signingbonus
RE: [Digital BW] Inconsistent nozzle checks / losing my sanity
2004-01-07 by ellery
Have you considered the cleaning carts - I remember there were carts filled
with cleaning solution. I think the residue of the different inks  could be
the cause of the clogging problems. Running clean cycles or you could just
print several copies of some color test pattern, wait a couple of hours
rerun the few copies print - all of this is to flush out any inks and soak
and clean the nozzles.
My own printer is starting misbehave a little but I guess it could be that
its getting on in years.
  Sent: Wednesday, January 07, 2004 12:08 PM
  Subject: [Digital BW] Inconsistant nozzle checks / losing my sanity
RE: [Digital BW] Inconsistant nozzle checks / losing my sanity
2004-01-07 by Ed Mathews
> From: D. Hill [mailto:hill14701@...]
> Sent: Tuesday, January 06, 2004 11:34 PM
<snip>
<snip>
I'd have to disagree with this, at least on a local level.  My Wallmart
gives pretty good color results, but their B&W has a terrible magenta
cast that they admit they can't get rid of. (dumb kids).
Ed
2004-01-07 by Bob Michaels
Does your printer give you inconsistent nozzle checks using original
Epson carts? If so, I have no clue to your problem. But if if works
with Epson carts, your problem is in your carts and everything you've
been doing is trying to solve a clog problem, which is not what you have.
The nozzles on my 1280 have been absolutely reliable for the 18 mos.
I've had it. Any problems I've had have been in the carts.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ranyart"
> Very frustrating.
> I have tried:
> sanity I have left.
> Thanks,
2004-01-07 by Tom Husband
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Michaels"
you've
have.
> Bob Michaels
I'd have to agree with Bob.  I've been having clogs on my 1280 with
UT ink and can't seem to get past them.  If I put Epson Color Carts
in everything is fine.  I've been refilling using the MIS bottom fill
carts and I think that's the problem.  There must be bubbles in the
carts when I'm done as sometimes a color is completely blocked off.
In the next day or two I'll be trying some top fill carts from Media
Street so we'll see if that makes any difference.
Tom
Ed,
Is the magenta cast originating from a greyscale file,
or a desaturated RGB file?  I have also found that the
Frontier prints straight greyscale files with a
magenta cast - However, the desaturated RGB file
outputs as a neutral print (go figure).
Another thing to check with them is if they are
running the prints "without corrections."  Sometimes
you really have to push them to run the files without
corrections, but that is key in getting a good print
as well as consistency.
If you can get them to do that, simple profiles via
Monaco EZ Color or other similar program will aid in a
good enough soft proof.  I've been using the locals
for about a year now and could not be happier for my
wedding work - proofs and final images, color and
greyscale.  And no complaints from the customers.
That an at .24 a print, it makes using an epson
obsolete...  <--- O.K. that deserves a flame.....
Don
--- Ed Mathews <ed@...> wrote:
> <snip>
> days,
> <snip>
> level.  My Wallmart
> terrible magenta
> kids).
> Ed
Do you Yahoo!?
> Sent: Wednesday, January 07, 2004 11:04 AM
I've given them both on CD.  No difference.
I'm sure that would help, but they are a very busy shop and I doubt they
would take the time to do that just for me.  The kids barely have enough
time to squeeze their zits. <g>
I too, tried it specifically for my wedding work.  The price was right,
but the quality at my local Wallmart just isn't that good.  Also, I
don't like having it say "Wallmart" on the back of every print.
Ed
2004-01-08 by jim hayes
Solidly agree with the folks that recommend installing Epson carts. Do
no more than 3 cleaning cycles or you'll really see LOTS of skipping
around spaces!
Make sure parking pad is clean and rubber perimeter is free of gunk as
well.
Also: what is your local climate? Altitude?
SW USA can get very dry, esp in winter. Terrible for lots of 3rd party
inks, even weekly- the 1280 Epson dye inks where I live
(sometimes<20%RH, 5000 ft). I use a humidfier, go for 42-50%RH, but it
only partly helps. The 2200 is magic; I get literally maybe four clogs
a year, always cleared in less than 3 cleaning cycles.
Disagree that "cleaning carts" will work. Misnamed, unless they
changed the purpose of them in the last year. They were used only when
transitioning from one ink to another, incompatible ink.
Jim Hayes
> Very frustrating.
> I have tried:
> sanity I have left.
> Thanks,
