Gamma setting in 'CurveTemplate.xls'
2004-01-09 by dp20031997
This question refers to the spreadseet: CurveTemplate.xls
 located in: Files > Image Processing  (on this site)
Could someone tell me what the gamma field in this spreadsheet should
be set to?
It seems to me that if it's not set to a value of 1, then the output
will not linear (ie 50%in = 50%out, etc).
In all the books I've looked in so far, none have given an exact
procedure to generate a dot gain (or transfer) curve - at least what
sort of curve the outpout should have.
Are we to shoot for a particular gamma in the print or is this just a
matter of taste?
I'm trying to use this to get better results from BO printing on a
Epson 820.
I'd appreciate any help at all with this as I'm about to mad will all
the prints, tests, experiments, etc. that I've done so far.
Even a response of just half a word ..........?
Thanks.
David Polasek
dp4391@...
Re: Gamma setting in 'CurveTemplate.xls'
2004-01-11 by Antonis Ricos
David,
> be set to?
Generally, either 2.2 or 1.8 depending on what your system is set up for.
> matter of taste?
It's not a matter of taste, rather part of your screen calibration and "color settings".
You may want to read up on Color Managment under Photoshop 6 or 7.  Also,
Windows like 2.2 and Macs like 1.8.
You are right that gamma = 1 would give you a linear plot, but that's rarely desirable
in a print (would be too light). Since you are experimenting anyway, you may want to
try all 3 gamma options and see what happens. Just be sure to coordinate all that
with the rest of your workflow environment (settings).
Antonis
2004-01-12 by dp20031997
Antonis,
Thanks.  That's what I needed for all to make sense.
David
