Atkinson for B&W
Atkinson for B&W
2004-01-15 by claudej1@aol.com
In a message dated 1/14/2004 6:36:30 PM Pacific Standard Time,
DigitalBlackandWhiteThePrint@yahoogroups.com writes:
Quick question:   Is anyone on the list using the Epson driver with Bill
Atkinson's profiles to print B+W photographs on the 7600 or 9600?   If so,
how
would you characterize the results?   Is it a viable option?
Sanders McNew
www.mcnew.net
Yep. Use them with RC papers. Dead neutral. Print color and B&W nest to each
other for portrait and wedding work. Quads on rag for personal work or PREMIUM
priced client work.
Claude
Re: Atkinson for B&W
2004-01-15 by J Michael Sullivan
my experience with both EEM and ESM is that the Atkinson profiles exhibit classic
metemerism, even though they are pretty darn good otherwise. Hence the need for
QTR
mjs
> how
> Sanders McNew
> www.mcnew.net
> priced client work.
> Claude
QTRIP Calibrating Ink Density w/PS
2004-02-05 by Tim Goodwin
QTRIP Calibrating Density with Photoshop
As I do not own nor have access to a densitometer, I am trying to
perform the Ink Density calibration for QTRIP v2.0 beta8 using
Photoshop 7 and my old Epson Perfection 1200 scanner. This is for an
Epson 1270 using MIS VM inks with Ebony black.
After doing the Hardware Ink Limitation Calibration(which I settled
on 90), I printed out the QuadtoneRIP Ink Pattern Page in Calibration
mode (with BOOST_K disabled). I then scanned the resulting image into
PS using Silverfast Ai 6. I disabled all calibration and color
correction in Silverfast and scanned in RGB mode converting to
grayscale in PS.
The problem is that my 100 Black is only 85%in PS (38 RGB). I assume
that I should be getting a reading of 100% or something close to it.
Although I can correct this in Silverfast or PS I would think that
this would defeat the whole purpose of the calibration process.
What have I done wrong and how can I correct this ?
Any and all help would be greatly appreciated.
Thanks
Tim Goodwin
Re: QTRIP Calibrating Ink Density w/PS
2004-02-06 by smthopr2000
Tim,
I've been doing this by eye as well, but without the scanner idea as my scanner can
not differentiate the lighter tones at all, and it seemed pointless.
What I do is to:
1. print out the test page with the ink levels at 100.
2. For each ink I set the ink limits individually based upon using my eyes to make
sure there is signifcant seperation in the darkest patches. IOW I choose the darkest
patch that seems to have a uniform step up to the next one and set the ink limit for
that ink using that patch.
3. I print out a new calibration chart with the new ink limits and cut the grey step
wedges into strips. Then by eye I place the lighter strip on top of the next darker strip
to calculate the ink% for curve making.
4. I set the overlap, or what ever it's called to about 20% and make a curve and print
out a step wedge using the new curve.
5. by eye, through some trial and error I adjust the overall gamma or the shadow or
hightlight gamma to match my screen with a step wedge displayed at gamma 2.2
This seems to get me very very very close. If I had a densitometer, I could then run
the "linearize" option and make a perfected curve, but I don't.
I will say that I can find no bumps in the gradient though. I'm very impressed.
-bruce
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tim Goodwin <tgvoz@p...>
> grayscale in PS.
> Thanks
> Tim Goodwin
2004-02-06 by Kees Brandenburg
Tim,
When I started with QTR I did not have a densitometer too. I had great
results with my old Umax powerlook II scanner and Vuescan. Nice about
Vuescan <http://www.hamrick.com> is that it can be used for density
readings. It uses the raw output of the CCD for that. Optical density
readings are measured as log (max_colour from CCD/raw_colour from CCD.
These density readings can be accessed in Vuescan when moving the
pointer over the scanned image while holding ctrl.
When I remeasured inkseparation points with my second hand XRite the
fell on exactly the same spots. Linearisation worked fine too.
Hope this helps
> grayscale in PS.
> Thanks
> Tim Goodwin
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Kees Brandenburg"
<ctb@z...> wrote:
> Tim,
> Hope this helps
Thanks Kees,
I do you vuescan for scanning (only scanning software that works in system X) with
my old microtek V600 and my UMAX Astra 1200s. Unfortunately, I find the neither of
these scanners can differentiate the 5% patch from the 0% patch or even the 10%
patch.
Thanks for the info about holding the ctrl in vuescan. I just may try again.
-bruce
Re: [Digital BW] Re: QTRIP Calibrating Ink Density w/PS
2005-01-11 by Mike Finley
On Fri, 06 Feb 2004 15:20:45 -0000, "smthopr2000"
<bagreene@...> wrote:
>Thanks Kees,
>patch.
>-bruce
You may find you can do a little better with the scanner if you cut
the calibration strips from the printed page, and scan them with black
paper behind them rather than white, to reduce the amount of reflected
light. bouncing around inside the scanner. You may need to do a
Vuescan 'calibration' scan first, with white paper.
Mike Finley, http://www.efikim.co.uk
