how to make .ACV file from tabular data???
Re: [Digital BW] how to make .ACV file from tabular data???
2004-01-18 by Editor P.O.V. Image Service
Mark Hahn wrote:
>how to make .ACV file from tabular data???  Is it really limited to
>only 20 points like in the curve dialog box?
No it isn't.. But you have to do the editing manually outside of
Photoshop, or use an application to edit the ACV file that will insert
more edit points..
Keith Krebs
"Just some guy," caretaker of the Multiverse's largest EPSON printer
User Community (highly recommended by Vogon Poets and MegaDodo
Publications), at:
http://groups.yahoo.com/group/EPSON_Printers/
and  the Multiverse's largest Canon printer User  Community at:
http://groups.yahoo.com/group/Canon-printers
"For the rest of you out there, the secret is to bang the rocks together
guys"
2004-01-18 by Mark Hahn
Ok, thanks, but still, how do you do it?  ie. what application?
Thanks for help in what should be simple... I just don't know how to
do it:)
Your help is greatly appreciated!
mark
PS  I've done a fair amount of searching and came up empty handed...
maybe just the wrong set of key words.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Editor P.O.V.
Image Service" <editor@p...> wrote:
to
insert
> more edit points..
> Keith Krebs
printer
> Publications), at:
together
> guys"
RE: [Digital BW] how to make .ACV file from tabular data???
2004-01-18 by Daniel Staver
I wrote a perl script once that creates .ACV files from tabular text
files. It's pretty specific in that it's only useful for linearizing a
21 step wedge. The text file has exactly 21 rows, and you need to skip 5
rows in each column to get down to the allowed 16 points that photoshop
will read.
If you insert more points than 16 (including the black and white points)
Photoshop refuses to read the file.
In the Photoshop 5.0 SDK they allow for 19 points on the curve, so they
must have cut down on the allowed number in one of the later versions.
It probably wouldn't take too much work to create a general purpose
script that could have completely separate input/output values for each
channel. Right now the input value is the same for all three channels
while the output values are different. I use this to measure a patch
with a densitometer for the input value and then I place the RGB values
for that patch at the corrected point.
Le me know if you're interested in a copy of the script.
Daniel Staver
http://daniel.staver.no
> do it:)
Re: how to make .ACV file from tabular data???
Thanks Daniel,
I'd appreciate getting a copy of your script.  All I'm trying to do
is create an overall adjustment curve to put on top of Paul's curves
and hopefully get a smooth gradient.  As it stands now I cannot print
anyting that has a fine gradient across it (like a side lit cylinder)
because of the waves in the tonal space and I figured a detailed
correction curve should be able to fix it.  16 pts seems pretty cheap
from Adobe, though I guess they could be stacked if needed.  Going
into ICC profiles seems like way more work and research than I'm
willing to put in.  The other option is to do all the curves in
something outside of PS...
Mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Daniel Staver"
to
linearizing a
skip 5
photoshop
> will read.
points)
they
versions.
each
channels
values
> Daniel Staver
to
> > do it:)
