You are mostly correct.
If you're starting with "Black Only" printing, you don't.need the "Color
cartridge" (ARC-T009-UT2).
Eboni is for Matte
Photo Black is for glossy or semi glossy
Some people have had success with Eboni on semi gloss papers.
Yes, you can swap between photo and eboni black until you figure out
which one you like best. If you go with a CIS, you can leave the tubes
off the black position cartridge and swap just that one out depending on
the paper choice....but if you stick with Black Only printing, CIS would
probably be more trouble than it's worth if you plan to swap.
BTW, I highly recommend the use of the "color cartridge" and Paul
Roark's curves with the UT-2 set.
m
jim0266 wrote:
> I finally ordered the 1280 refurbished from Epson after a lot of angst
> and reading, deciding that I don't need the 2200. From what I've read
> the UT2 inks seem to be the way to go, though trying to navigate the
> MIS website is frustrating. I want to experiment with QuadtoneRIP and
> black-only printing to find what works best for me.
> Before going to a continuous feed system I want to first start with
> carts. On
> http://www.inksupply.com/index.cfm?source=html/ultratone.html there
> are three carts for UT2: The Eboni black, the Photo black and the
> Color Cartridge. My understanding is that I need the Eboni black
> (ARC-T007-UTK) to print on matte papers or the Photo black
> (ARC-T007-UPK) to print on glossy papers. Then after deciding between
> these two inks I need to add the "Color cartridge" (ARC-T009-UT2) as
> the second cart in the printer. So far do I have this right?
> Assuming I am correct above, if I am using carts should I be able to
> swap out the Eboni black for the photo black so I can change papers
> while experimenting? Or does that open a can of worms? But once I go
> to a continuous feed system does that pretty much lock me into a Eboni
> black or Photo black world?
> Thanks,
> Jim
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
> AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
