Epson 2200 B and W
2004-02-06 by nsams2002
I've read, here and there on the list, about problems printing Black and White with the Epson 2200, using the stock Epson ink set. Could someone summarize for me please. Thanks in advance from Norm.
2004-02-06 by Paul D. DeRocco
> From: nsams2002 [mailto:normsams@...] > > I've read, here and there on the list, about problems printing Black > and White with the Epson 2200, using the stock Epson ink set. Could > someone summarize for me please. In black-only mode, you wind up with a very warm, almost brown, print, and it doesn't use the light black so the grain is slightly visible in the highlights. (I'm told the light black ink is even browner.) In color mode, the stock profiles don't give a very neutral color balance, and even with a custom profile, there's some residual metamerism. Having come from a 2000P, I don't think there's very much, but others disagree. You can get essentially perfect grayscales using the Epson color inks with a RIP like ImagePrint, but that's extra money. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
2004-02-06 by julie stapen
Hi Paul, Thank you so much for your time and expertise in responding to my question. I appreciate your help so much. I am new at this, willing to spend the money, but don't know what an RIP like image-print is.... Would you mind elaborating on that... What it is and where I could get something like that? Thank you!! Julie Stapen --- "Paul D. DeRocco" <pderocco@...> wrote: > > From: nsams2002 [mailto:normsams@...] > > > > I've read, here and there on the list, about > problems printing Black > > and White with the Epson 2200, using the stock > Epson ink set. Could > > someone summarize for me please. > > In black-only mode, you wind up with a very warm, > almost brown, print, and > it doesn't use the light black so the grain is > slightly visible in the > highlights. (I'm told the light black ink is even > browner.) > > In color mode, the stock profiles don't give a very > neutral color balance, > and even with a custom profile, there's some > residual metamerism. Having > come from a 2000P, I don't think there's very much, > but others disagree. > > You can get essentially perfect grayscales using the > Epson color inks with a > RIP like ImagePrint, but that's extra money. > > -- > > Ciao, Paul D. DeRocco > Paul mailto:pderocco@... > > __________________________________ Do you Yahoo!? Yahoo! Finance: Get your refund fast by filing online. http://taxes.yahoo.com/filing.html
> From: julie stapen [mailto:jsstapen@...] > > Thank you so much for your time and expertise in > responding to my question. I appreciate your help so > much. I am new at this, willing to spend the money, > but don't know what an RIP like image-print is.... > Would you mind elaborating on that... What it is and > where I could get something like that? It's a standalone program that prints without going through the standard Epson driver, so it has its own algorithms for laying down the dots. ImagePrint (www.colorbytesoftware.com) has a B&W mode, with its own proprietary profiles, that uses mostly black ink (and I presume light black), mixing in only enough color ink to smooth out the grain and eliminate the brown cast. It avoids using the yellow ink, which is reputedly responsible for most of the 2200's metamerism. The result is a dead perfect grayscale, for $500. My only complaint about them is that they want $500 for each printer you want to use (much more for large format), so I think that puts it decisively into the pro category, not of much interest to most hobbyists. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
2004-02-06 by Tom OConnell
Norm- you don't say whether you are mac or pc...there are several free solutions for mac. Image Print seems to yield the best results for pc (for both color and BW). I agree with post that says gray balancer is worthless...less than worthless, you waste a lot of time and paper and ink trying to make it work. I think the Picto Rico profiles for their papers work quite well, you might give that a try. And the MOAB papers also have free profiles (I haven't tried them, but the paper samples look quite nice). You will get your best results with Matte Black ink on a good paper like Photo Rag or Espson Velvet (though there is a lot of controversy about the quality of EEM, it looks great for testing). cheers, Tom O'Connell
2004-02-06 by lea
Does this program work using lustre papers or does it work best on matte finishes? Thanks, Lea
----- Original Message ----- From: "Paul D. DeRocco" <pderocco@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Friday, February 06, 2004 11:42 AM Subject: RE: [Digital BW] Epson 2200 B and W > From: julie stapen [mailto:jsstapen@...] > > Thank you so much for your time and expertise in > responding to my question. I appreciate your help so > much. I am new at this, willing to spend the money, > but don't know what an RIP like image-print is.... > Would you mind elaborating on that... What it is and > where I could get something like that? It's a standalone program that prints without going through the standard Epson driver, so it has its own algorithms for laying down the dots. ImagePrint (www.colorbytesoftware.com) has a B&W mode, with its own proprietary profiles, that uses mostly black ink (and I presume light black), mixing in only enough color ink to smooth out the grain and eliminate the brown cast. It avoids using the yellow ink, which is reputedly responsible for most of the 2200's metamerism. The result is a dead perfect grayscale, for $500. My only complaint about them is that they want $500 for each printer you want to use (much more for large format), so I think that puts it decisively into the pro category, not of much interest to most hobbyists. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@... Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
> From: lea [mailto:lea@...] > > Does this program work using lustre papers or does it work best on matte > finishes? The ImagePrint web site has a huge library of profiles for all sorts of papers and inks. Since I don't actually own it, I've so far only had the opportunity to see one of my own images done on Premium Luster. However, you can download it and try it out--it'll print DEMO across the image, but you can see how good the grayscale is. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
