Something like Autoprint for OS X?
2004-02-11 by jim0266
My plan is to eventually move to a continuous flow system. It seems that one of the tricks is to use the printer consistently to avoid clogs. That's where an application like Autoprint comes in handy. But it only works on Windows and OS 9. I found a few tricks/tips on the MIS site: "If you have a Mac OSX or early Windows 3.1 machine, then there is software available that will achieve the same results. One of these companies is Peerless. If there is no Autoprint software for your computer, there is another less elegant solution. From your local hardware store, get a low cost timer switch. The type that will turn on light and appliances while you are not at home. Install this on your printer power line. Set it to come on for 15 minutes during the day or night and then go off again. When the printer power is turned on, the printer will do a cleaning cycle. This will keep your CFS lines fresh." Has anyone tried the timer trick or found anything better? Something like Autoprint probably requires the printer to be on all the time. Tied to this question, do folks try to keep their printers covered when not in use? I would like to keep mine covered when not in use but if I had to have it on all the time I would be afraid to cover it, blocking the vent holes and possibly shortening its life. The timer trick seems like a good alternative for keeping the printer covered and still keeping the lines fresh.
