Newbie Needs Help with Using Curves (Paul Roark)
2004-02-11 by bad2maxxx
Hi-
After seeing how far digital prints have improved, I am leaving my
wet darkroom behind and going digital!
I have ordered a Nikon Coolscan V film scanner, a refurb Epson 1280
printer, and will be purchasing the MIS CFS system, using the UT2
with Eboni inks.
In my research, I am having some trouble understanding how to use
the "curves" for obtaining a specific tone.  I have PS Elements 2.0
(is this sufficient?) and I know we need to convert the greyscale
image to RGB.  But reading the MIS website regarding Paul's curves
for specific papers (I plan on using PhotoRag) I don't understand
how they are to be applied.
For example, for photograg, it says "UT2-PhotoRag-Neutral-1"
and "UT2-PhotoRag-Carbon-" and "UT2-PhotoRag-Sepia-1 (use 16 bit;
there is only one sepia curve)".
What is the significance of the above? What exactly do we do in
Photoshop to apply the curves?
I understand the application of obtaining tones using the Epson
driver and moving the sliders for the C M and Y, it is the PS curves
that I am struggling with.
Any help in this regard would be greatly appreciated!
Rob
Re: Newbie Needs Help with Using Curves (Paul Roark)
2004-02-12 by Tom Husband
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bad2maxxx"
<bad2maxxx@y...> wrote:
> Hi-
> with Eboni inks.
Rob,
Photoshop Elements doesn't have the curve function so you won't be
able to use it.  In Photoshop you'll change the image to RGB and then
go to curves under Image>Adjustment.  When the curve box opens hit
the load button and navigate to where you stored the curves.  Select
one and apply.  Use the resulting image to print.
An alternative to Photoshop for applying curves is Picture Window Pro
for around $50.  It's a very nice piece of software designed for
digital images.
I'm not sure why the curves are numbered.
Hope that helps a little.
Tom
2004-02-12 by randyrancier
It is my understanding you can use a printer with the UT2 inks with
Photoshop Elements or any other software using the slider in the
driver to print from warm to neutral.  If you want to print warmer
to sepia, or cooler you will have to have the "full-blown" version
of Photoshop 5.5 or higher, or use the Picture Windows program and
use the curves.  If I'm wrong somebody please correct me!
> Hi-
1280
> with Eboni inks.
2.0
curves
> Rob
2004-02-13 by bad2maxxx
Thanks for the responses!
Bummer about Elements not working with the curves.
I'll see how well things work just using the Epson driver.
Rob
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "randyrancier"
with
> > Hi-
my
> 1280
UT2
> > with Eboni inks.
use
> 2.0
greyscale
curves
understand
bit;
> curves
> > Rob
Re: [Digital BW] Re: Newbie Needs Help with Using Curves (Paul Roark)
2004-02-13 by D. Hill
Rob,
By any chance are you connected to a mac?  If so, you
could run quadtoneRIP and get similar results to the
curves.
Don
> driver.
> Rob
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online.
http://taxes.yahoo.com/filing.html
2004-02-13 by Max Clark
Nope, I am using a PC.
Still trying to decide whether I should go full
photoshop or try the much cheaper alternative, Picture
Window.
Rob
--- "D. Hill" <hill14701@...> wrote:
> Rob,
> you
> curves.
> Don
> > driver.
> > Rob
> Do you Yahoo!?
> online.
Do you Yahoo!?
Where Can I Download Curves for UT2 Inkset?
2004-02-22 by Max Clark
This seems like a stupid question, but I am having
difficulty downloading the UT2 curves.  I have
attempted to download them from Paul's website without
luck, and I can't locate them on the MIS website.
Any suggestions?
Thanks!
Do you Yahoo!?
Yahoo! Mail SpamGuard - Read only the mail you want.
http://antispam.yahoo.com/tools
Re: [Digital BW] Where Can I Download Curves for UT2 Inkset?
Scratch that request, I finally figured it out!
Sorry!
> without
> Any suggestions?
> Thanks!
> Do you Yahoo!?
Do you Yahoo!?
How to Make Cooler Prints with UT2 Inkset?
I've been playing with my new Epson 1280 and UT2 Ink
system over the weekend, and I am very pleased
overall.
However, there are times when I like really cool
tones.  It looks like the curves start at "neutral"
then "carbon" up to the warm sepia tones.
The neutral curve appears to be just that...very
neutral.  Are there any curves or recommendations on
how to get cooler prints than what the neutral curve
provides?
Thanks.
Do you Yahoo!?
RE: [Digital BW] How to Make Cooler Prints with UT2 Inkset?
2004-02-22 by Paul Roark
>...there are times when I like really cool
>provides?
I agree cool curves would be good, but I have not had time to making them
yet.  I explained how to adjust the neutral curve for warmer or cooler
prints in my Readme file.  Basically, just make offsetting moves of the cyan
and magenta inks (red and green curves).
The one cool curve I did make, for PermaJet's Oyster paper, moved the
neutral Red curve down (adding more ink) 18 at 63 (that is, from (63, 93) to
(63, 75), 32 at 127 (the mid point), and 41 at 191.  I moved the green curve
up 22 at 63, 37 at 127, and 46 at 191.  That curve also has some shadow
point below 63 that had some offsetting moves.  The changed above took the
tone from neutral to 0.06 units cool.  (Carbon is 0.10 warm for comparison.)
I think about 0.06 units cold is getting close to as cool as I'd want to go
and still have a "normal" looking print.  If you go too far the print starts
looking blue instead of gray.
For UT2 information, curves, and settings see:
http://home1.gte.net/res09aij/
Thanks for the quick response Paul!
I will give those numbers a try and see what happens.
I will look forward to you providing cool curves in
the (hopefully near) future.
Thanks for all your hard work in making the MIS UT2
ink set work as good as it does!  No more wet darkroom
for me!
> on
> curve
> >provides?
> paper, moved the
> Paul
> www.PaulRoark.com
Do you Yahoo!?
