Kiefer,
I had the same problem recently. Selecting "user defined" always
gives a slightly bigger box on the screen (although I too
experienced some of the funky sizes you explained a couple of
times). I'm guessing this is because they pad the dimensions
assuming borders. Anyway, the way I solved this was:
1) Import photo, right-click on the photo and select "center region".
2) Select "file->print" from ImagePrint. The "print dialog" box
pops up. Click on "options", and for the The Epson 2200 their are
two options, "borderless" and "center margins". Select both (If you
then click on "apply" these should stay as the defaults, so you
don't have to repeat this step for subsequent prints).
This seems to do the trick for me, and I get perfectly centered
prints on all papers (4x6, 5x7, 8.5 x 11) I use.
Also, maybe try "user-defined" for your 8.75 x 11.75, and then save
it if this works. I just tried this and my frame size was about 9 x
12, which seems about right, since it is slightly bigger than the
input values (consistent with the slightly larger frame-size for all
other defined sizes).
Brian
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "slightlyoutoffocus"
<by_design@y...> wrote:
> I recently purchased and installed IP 5.6 on my Win 2000 PC, and
am
> using it successfully to print very impressive images with my
Epson
> 2200. But one problem is driving me crazy. I print many 8"x8"
images
> on 8.5"x11" (letter size) paper. When I select Letter Size paper
in
> IP, I get a frame whose dimensions are "usually" 8.25"x10.25". If
I
> create a user defined paper size, specifying 8.75"x11.75",
> I "usually" get a frame that is 8.5"x11". I have to say usually
> because I sometimes get even more strange dimensions. But
regardless
> of the size I specify, or the displayed dimensions of the box, I
am
> unable to get a print centered, no matter what combinations of
right-
> clicking or borderless or other settings I select.
> This behaviour is so damaging to normal layout expectations, that
I
> am sure it couldn't be a bug that Colorbyte has left un-fixed. It
> must be cockpit error (and I'm the hapless pilot).
> So: Simple question: How do I get a centered print on 8.5"x11"
paper?
> It can't be this difficult!
> Kiefer Elliott
> Vancouver, Canada
