Switch out C82 BW & Color Carts?
2004-02-24 by LAJacobs
I want to order the MIS BW inkset for my C82. Is it possible to
switch out cartridge sets and go back & forth between color & BW? If
so, is it necessary to plug the cart nozzles & with what?
TIA, Linda J.
RE: [Digital BW] Switch out C82 BW & Color Carts?
2004-02-24 by Paul Roark
Linda,
Yes, it is possible to switch inksets. Just tape the outlets of the used
carts.  When you install used carts back in the printer, you'll have to do a
few cleaning cycles to get it going again.  Air gets into the outlets.  I
recommend you stay with MIS black, however, instead of putting the Epson
black ink back into the printer.  I believe the Epson black has some dye in
it.
For UT2 information, curves, and settings see:
http://home1.gte.net/res09aij/
Re: [Digital BW] Switch out C82 BW & Color Carts?
2004-02-25 by LAJacobs
<paul.roark@v...> wrote:
> (snip)...I recommend you stay with MIS black, however, instead of
putting the Epson black ink back into the printer.  I believe the
Epson black has some dye in it.
Thanks, Paul - and especially thanks for the above tip about staying
with the MIS black. I would never have thought to do that. I'm using
MIS Ultrachrome match for the color set so I'll just leave the black
from the BW set in...should work fine! What fun I will have!
Linda
