R800 BO was new UT EZ inks for C84 printers
2004-02-25 by Paul
At 4:15 PM -0500 2/24/04, Carl Schofield wrote: >I was looking forward to seeing a BO print from >a machine capable of putting out 1.5 pl drops. Hi Carl, First off, yes, the new R800 is a very impressive printer. My first print out of it was color and spot-on, an excellent profile, no metamerism at all, and the new gloss optimizer works well. Huge difference - the red and blue inks' effect on gamut. Lotsa greens in the print too. But I bought it for a B&W gig the next some months and so followed the thread here. Just starting on it, I'm yet to get up to speed on the entire workflow. So, most obviously, an rgb scan of B&W film printed with yellow hilites and bluish mid/lo-tones when printed color. Same results even if converted to grayscale before printing. No grain aliasing of the 400 speed film/2700 ppi scan. Paper - Premium Glossy. I can't find the Grayscale option. Just Color or Black. And very curiously, according to the User's Guide (book), "select Color (for color documents and black and white photographs) or Black (for black text documents), while from the online Help, "When you select Black or Grayscale colors are automatically converted to grayscale values. If your document includes color, chose color. If you are printing black text only or you want colors to print as varying shades of gray, chose Black or Grayscale"." Contradictory????!!!!! I'm Mac 9.1 and the USA software is v 1.56A while I see Epson's UK site has v 1.5b. Does anyone know if that software is different in this regard and if there's a reason I shouldn't download and use that? BO printing removes the color casts. A quick loop look though I do think I'm seeing a small amount of blue dots too. The dots more obvious in BO, the 1.5 picoliter is just incredibly fine. Overall the image doesn't appear to have as smooth tones as rgb which looks like it may also be due to the same sharpening being too much for BO. Not good enough yet, so I'll be working on this if you want any particular tests or test prints. Next - EEM. -- Paul http://www.paulericjohnson.com
