Epson 1270 with MIS VM ink - prints look muddy
2004-02-26 by Bob Thornburg
I've installed the MIS continuous flow system with the VM inkset on
my Epson 1270 printer.  The tone of the blacks is superb, but I lose
detail in the shadow areas.  The prints come out looking muddy.  I've
tried using Epson matte paper, and Epson watercolor paper, and used
the PQIJ option in the print driver.  Does anyone have any ideas?  I
would greatly appreciate any help.
Bob
RE: [Digital BW] Epson 1270 with MIS VM ink - prints look muddy
2004-02-26 by Paul Roark
>detail in the shadow areas.  ...
It sounds like a settings problem.  There are also several series of 1270
curves out there.  The best are those that start with "vm70."
The settings are as follows:
Photoshop general color settings (Edit, Color Settings) should be Photoshop
5 defaults, except that the RGB Working Space is changed to Adobe RGB
(1998).
Epson driver dialog box settings:
	(Only the critical ones for the VM inkset are noted.)
	Media Type:  Matte Heavy Weight,
	Ink:  Color
	Print Quality: 1440
	Color Management:  No Color Adjustment
	Print Space:  Same as Source
Be sure there is no embedded profile in the file.
Hope this works.
For UT2 information, curves, and settings see:
http://home1.gte.net/res09aij/
Re: [Digital BW] Epson 1270 with MIS VM ink - prints look muddy
2004-03-02 by bobtburg@aol.com
In a message dated 2/25/2004 7:27:44 PM Mountain Standard Time,
paul.roark@... writes:
(1998).
    Ink:  Color
    Print Quality: 1440
Hope this works.
Paul,
Thank you very much for the help.  I've tried these settings and the quality
has improved somewhat, however, the prints are still coming out looking
somewhat muddy.  I'll try contacting MIS and see if they can offer any ideas.
Thanks again,
Bob
