Re: [Digital BW] Re: PIEZOGRAPHY bw icc GRAYSCALE
2004-03-02 by sdmey4@aol.com
In a message dated 3/2/2004 9:14:37 AM Pacific Standard Time,
tyler@... writes:
> Depending on printer model, the inksets are different for the plugin
> vrs the icc profiles. If the plugin is working for you, but not the
> profiles, having the correct inkset would be the first thing to look at.
> Tyler
> Yes, Tyler is right. The Icc profile method I'm pretty sure uses the inks in
different positions than the plugin. Same inks just different positions.
Steve M.
