HP 7660/7960
HP 7660/7960
2004-02-27 by sl91911
I am in market for new printer and want to do mainly BW with some
color. I would like a one printer solution if possible.
The 7660/7960 have been discussed to some extent here. For 8x10 work,
is the most current consensus one of these printers or the new R800 ?
Everything I have read thusfar is not conclusive.
                              Stuart
Re: HP 7660/7960
2004-02-27 by Mark Hahn
I think that is should be conclusive that the hp is better for b&w
work.  The hp tri-tone system is excellent.  I prefer the Epson
dither pattern, but I have only found one photo to be a real problem
with the hp woven pattern and that was a poorly exposed T400CN 35mm
image scanned at a measly 2880dpi.  There have been too many posts
noting color casts in the R800 to dismiss.
As to color, I printed one 4x6" on my 7660 and it looked good, but
personally I find the 20 cent prints from the fuji system at
Walgreens to be cheaper and easier so I don't think I'll be printing
much color at home.
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sl91911"
work,
R800 ?
>                               Stuart
Re: HP 7660/7960
2004-02-28 by Radimus
Hi, Stuart.  I have a 7660 and overall I can't complain.  It's limited
in the kind of papers that can be used.  Since the ink is dye-based
you have to use an encapsulating paper of some kind to get any kind of
longevity fopr the prints.  That pretty much limits you to HP Premium
and Premium Plus Photo in glossy and matter or Ilford Classic Galerie.
     However it's super easy to use and was only $150 US.  The ink is
pricey at $25 each for the gray cartridges, but you never have to deal
with clogs.
Biggest issue with these printers at this point seems to be the dither
pattern.  It looks like extremely fine microbanding, but you have to
either stick your nose in the print or use a loupe to see it.  I
recall reading somewhere that HP intends to fix this issue in the next
driver update, but I cannot confirm that.
Anyway, I'm quite happy with mine.
Rad
>                               Stuart
Re: Re: HP 7660/7960
2004-02-28 by Steve Bell
On 28/2/04 11:24 am, "DigitalBlackandWhiteThePrint@yahoogroups.com"
<DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Message: 9
>  Date: Sat, 28 Feb 2004 04:24:31 -0000
>  From: "Radimus" <radimus@...>
> Subject: Re: HP 7660/7960
> Rad
Can anyone comment if this minor problem is noticeable on prints made both
with the Windows and Mac OSX driver?
Steve Bell
Re: HP 7660/7960
2004-02-29 by sl91911
Mark,
    Thanks for the straight talk.
   What paper do you use ?
    What do you estimate your cost per print for an 8x10 to be ?
   Are there any advantages to the 7760 or 7960 ?
               Stuart
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark Hahn"
> much color at home.
> mark
> work,
> R800 ?
> >                               Stuart
Re: HP 7660/7960
Thanks for the info Rad,
What do you estimate your cost per print, 8x10, with the HP paper ?
                Stuart
   --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Radimus"
> with clogs.
> Rad
> >                               Stuart
Re: HP 7660/7960
2004-02-29 by Mark Hahn
Umm, if you are coming from a quadtone and EEM it's a lot, between
$1.50-3.00, but it is nearly fool-proof and so far it is so close to
my screen that I have only had to print one to get the "perfect
print."  With my MIS VM setup it seemed that I would always end up
printing 3-5 prints before getting it right.  I'm using the HP
Premium Plus Glossy.  Not trying to save any money here (except that
#59 carts at Target are only $23.99).  The resuls are excellent and
so far everyone I have shown them to has been blown away.
There is no benifit to buying the 7760 IMO except for more buttons
and a monochrome display.  I'm never going to print straight from a
card, and if I did, I would do it at Walgreens because it would be
faster and cheaper.
No one has posted anything, but from my reading of the specs it
sounds like the 7960 would actually allow for toned prints, but no
one, including hp, will come right out and say so.  I'm happy enough
with my 7660 so I'm done testing them, but if you take a memory card
with a toned b&w image on it you should be able to make a print in
the store... someone should try it out.
mark
> Mark,
>                Stuart
Re: HP 7660/7960
2004-02-29 by Radimus
I posted a message to the list to that effect a little while back.
This was just based on HP's numbers for prints per cartridge.  Run a
search and you should be able to find it.  As to my exact cost, I
don't really know.
Rad
>                 Stuart
> > with clogs.
> > Rad
work,
R800 ?
> > >                               Stuart
