Problem with UT2 / 1280
2004-02-28 by rbehr2001
I recently installed a UT2 inkset in a new factory rebuilt Epson 1280
printer. When I print using Slider Controls or curves, I get very
uneven distribution of densities at the light and dark ends of the
scale as measured with a X-RITE 810 densitometer;
Light		Density
0%		0.09
5%		0.11
10%		0.14
15%		0.18
Dark		Density
85%		1.71
90%		2.05
95%		2.23
100%		2.24
Between 20-80% the distribution is relatively even. Using curves, the
distribution is even worse. I have reviewed the latest instructions
on the MIS website and I believe I'm following them pretty closely.
Any suggestions as to what the problem might be?
RE: [Digital BW] Problem with UT2 / 1280
2004-02-28 by Paul Roark
I have some slider setting for glossy paper, UT2 & 1280 at
http://home1.gte.net/res09aij/UT2-Readme.htm .
Be sure the settings are as set out in that Readme file.
Let me know if MIS has different settings.
__________________________
Sent: Saturday, February 28, 2004 9:38 AM
Subject: [Digital BW] Problem with UT2 / 1280
Light		Density
0%		0.09
5%		0.11
10%		0.14
15%		0.18
Dark		Density
85%		1.71
90%		2.05
95%		2.23
100%		2.24
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
Re: [Digital BW] Problem with UT2 / 1280
Instructions and slider positions are the same as I used as the MIS
site.
> Paul
> www.PaulRoark.com
> From: rbehr2001 [mailto:rsbehr@h...]
1280
> Light		Density
> 0%		0.09
> 5%		0.11
> 10%		0.14
> 15%		0.18
> Dark		Density
> 85%		1.71
> 90%		2.05
> 95%		2.23
> 100%		2.24
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
Owner and
section:
PRINT
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
I'd re-check the settings and be sure there is no embedded profile in the
file that is being printed.
I don't have an easy way to check ink densities or positions.  It sounds
like the positions must be OK.  If not you'd have more serious problems.
What paper are you using?
_____________
Sent: Saturday, February 28, 2004 2:45 PM
Subject: Re: [Digital BW] Problem with UT2 / 1280
site.
> Paul
> www.PaulRoark.com
1280
> Light		Density
> 0%		0.09
> 5%		0.11
> 10%		0.14
> 15%		0.18
> Dark		Density
> 85%		1.71
> 90%		2.05
> 95%		2.23
> 100%		2.24
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
Owner and
section:
PRINT
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
page.
them short.
the membership.
Yahoo! Groups Links
2004-02-29 by rbehr2001
Paul,
I'm working with preloaded cartridges from MIS so ink
density/position should not be a problem.
When I go to "assign profile" (in Photoshop CS) the "don't color
manage this document" is checked which seems to indicate no profiles.
Also, the values are as indicated, i.e. 90%=90%, 80%=80%, etc., on
the info palette.
I'll recheck everything in the morning. I'm using Epson Premium
Semigloss PP. I'll also try a different paper.
Bob
in the
sounds
problems.
> Paul
> _____________
> site.
> > Paul
> > www.PaulRoark.com
> 1280
> > Light		Density
> > 0%		0.09
> > 5%		0.11
> > 10%		0.14
> > 15%		0.18
> > Dark		Density
> > 85%		1.71
> > 90%		2.05
> > 95%		2.23
> > 100%		2.24
> the
instructions
closely.
2004-02-29 by Paul Roark
Bob,
I found my Premium Semigloss test strips with the settings that are in my
UT2 Readme file. As the Readme file indicates, and somewhat consistent with
your readings, the first/lightest 3 steps are lighter and lower in contrast
than my target densities.  I measure the paper base (0%) at 0.05, 5% = 0.08,
10% = 0.11, and 15% = 0.14, which is my target for 10%, not 15%.  After this
the steps have normal and then higher than normal contrast.  At the dark end
I originally had 2.40 at 100% and 2.0 at 95%.  These have now dropped to
2.14 and 1.93, which is still reasonably good.
The densities you reported were:
> Light		Density
> 0%		0.09
> 5%		0.11
> 10%		0.14
> 15%		0.18
> Dark		Density
> 85%		1.71
> 90%		2.05
> 95%		2.23
> 100%		2.24
I'd guess your system is working about like mine at the light end, but the
dark end seems to be giving significantly different results.  The steps on
my tests strips at the dark end appear to be well separated.
For UT2 information, curves, and settings see:
Paul,
Sounds like my problems might be a combination of the original curve
being slightly off and minor printer differences. I'm going to switch
to Eboni for Matt and Gloss, retry with Eboni Curves and then fine
tune the results for my printer. Thanks so much for the help.
Bob
> Bob,
in my
consistent with
contrast
5% = 0.08,
After this
dark end
dropped to
> > Light		Density
> > 0%		0.09
> > 5%		0.11
> > 10%		0.14
> > 15%		0.18
> > Dark		Density
> > 85%		1.71
> > 90%		2.05
> > 95%		2.23
> > 100%		2.24
but the
steps on
> Paul
> www.PaulRoark.com
