Thanks! I assume by "the last entry", you're referring to the entry at the bottom
of the page where it lists this cartridge set: "UTRATONE B&W FOR 2200 WITH
BOWHAUS INK CONFIGURATION - SEPIA TO COOL PRINTS "
If so, I have several questions (for anyone): (1) is this the UltraTone 2 inkset
Paul is developing or is it the "original" UT set? (2) If this is the original UT
set, then why is UT-2 needed/what will it do differently? (Just eliminate the
need for additional software?) ; (3) Is this the inkset that MIS is planning on
making available for the 7600/9600? Or is what will be available for the 7600/
9600 a different inkset?
I'm very confused now. If there's currently an inkset that will print B&W on both
matte and glossy, what were all the "Who Needs a 4000 -- Eboni black"
threads a couple of months ago about?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington" <
roy@h...> wrote:
> MIS has been shipping a set pretty close to this (no gloss overcoating)
> for quite a while. See the last entry on:
> http://www.inksupply.com/index.cfm?source=html/ultratone.html
> It has the two kinds blacks, three grays, and two toners. 4 or 5 grays
> is way overkill for the modern printers with variable dot sizes. In fact
> 3 grays are probably more than really necessary.
> It does require special software QuadToneRIP or Bowhaus to drive the
printer.
> Roy
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chipcarterdc"
> <chipcarterdc@h...> wrote:
> > I'm wondering whether anyone (Lyson, MIS, etc) makes a B&W inkset for
the 7
> > color ultrachromes that looks like this:
> > position (1): glossy black
> > position (2): matte black
> > positions (3)-(7): 5 shades of black ink (or 4 shades plus a glossy
overcoating
> > used when printing on glossy)
> > It seems fairly logicial, given that many people use only 4 shades of gray
ink
> > for B&W currently (right? isn't there where the term "quadtone B&W
printing"
> > comes from?). Why not maximize the use of the additional ink positions in
> > 7 color ultrachrome printers?
> > I know that initial reports are that the UT2 inkset will work on both matte
and
> > glossy paper. But that's not available or at least not widely available yet.
> > Here's my other hypothetical for a 3rd pty ink manufacturer: just make one
"tri-
> > color gray" cartridge, like HP does. Then you just substitute this new
cartridge
> > with multiple levels of gray for the Epson black. When printing full color, it
just
> > uses one of the blacks in that cartridge; when printing B&W, it uses all 3.
> > Thoughts? (yes, special software would likely be required to implement
> > either)
