UT2 1280 Curves/Paul Roark
2004-02-29 by rbehr2001
Paul, Page 6 of your http://home1.gte.net/res09aij/UT2-Readme.htm indicates that the red and green curves have only 3 internal points on them. But the curves I've used (Prem Semi Gloss for Eboni & Photo Black) have many points on them. Am I missing something? Thanks, Bob
2004-02-29 by Paul Roark
Bob, So true. EEM was the first one I did, and it didn't need any other points on the main curves, as I recall. Subsequently I found the shadows below 75% often needed some points. I should modify the Readme to reflect this. What I've tried to do is hold the points down in the midtones, which is where the tones show the most. The idea is to make it easy for everyone to slightly modify the curves/tones by making offsetting moves of the red and green points. In the shadows where there are points on some curves, this works to a certain extent also, and visual inspection of a 21-step file print will, I think, be easy enough to get those areas under control. Paul www.PaulRoark.com For UT2 information, curves, and settings see: http://home1.gte.net/res09aij/ ____________________
-----Original Message----- From: rbehr2001 [mailto:rsbehr@...] Sent: Sunday, February 29, 2004 9:55 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] UT2 1280 Curves/Paul Roark Paul, Page 6 of your http://home1.gte.net/res09aij/UT2-Readme.htm indicates that the red and green curves have only 3 internal points on them. But the curves I've used (Prem Semi Gloss for Eboni & Photo Black) have many points on them. Am I missing something? Thanks, Bob Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
2004-03-05 by Robert Behr
Paul,
Thanks for the help. I've started working on custom curves. I'm trying to establish what an ideal distribution of values should be. I note that in the Hobeman instructions for "Customizing MIS Ultratone Curves" suggest that Grayvalue percentages (21 step) vs. RGB values (0-255) be in a linear relationship. However, when I measure 21 step grayscales printed on a 2200 (with color ink) and in Piezography, I get significantly different relationship (which is closer to what I get from your curves).
The results are as follows:
Percent RGB
0
255
5
250
10
245
15
239
20
233
25
226
30
219
35
212
40
204
45
195
50
185
55
174
60
162
65
149
70
135
75
120
80
104
85
86
90
64
95
35
100
0
What goals are you using?
Bob ----- Original Message -----
Sent: Sunday, February 29, 2004 1:37 PM
Subject: RE: [Digital BW] UT2 1280 Curves/Paul Roark
Bob,
Paul,
Bob
page.
them short.
the membership.
Yahoo! Groups Links
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
[Non-text portions of this message have been removed]2004-03-05 by Paul Roark
Bob, >... I've started working on custom curves. I'm trying to establish what an >ideal distribution of values should be. I have never seen a very good explanation of this issue, just factors to take into consideration. I've asked in the past, "What is linear?" I don't think there is a simple answer. > I note that in the Hobeman instructions for "Customizing MIS Ultratone >Curves" suggest that Grayvalue percentages (21 step) vs. RGB values (0-255) >be in a linear relationship. However, when I measure 21 step grayscales >printed on a 2200 (with color ink) and in Piezography, I get significantly >different relationship (which is closer to what I get from your curves). In general the say the human eye follows the logarithmic scale. As such the f-stops and log scales of the densitometers should be close. However, it is also the case that our ability to distinguish steps in the darker regions is less than in the brighter or midtone sections. So, if you assume that the dmax on a matte paper is 1.65 and the paper white is 0.05, 0.80 would be the arithmetic midpoint. If, however, this is used at the 50% density, the scale looks dark. If I use a log scale that goes from 0.05 to 1.65, measure the distance between the ends and divide it in half, the midpoint on the scale is just below 0.30 -- too light (but close to where some old Epson's put the BO midpoint). (I'm sure some with a strong math background could do a better job here than I, but I also think a background in the human visual system is needed -- another field I'm not formally trained in.) What I did was work from a pragmatic perspective. I was using the PiezoBW system. I wanted my files to be printable and the images to be consistent with both systems. So, I took a number of PiezoBW 21-step test strips and averaged them. The average for 50% was 0.61. Smoothing the curves gave me a 25% of 0.29 and the 75% of 1.03. At the dark end, the dmax is a critical factor that needs to be considered for, especially, what is between about 70% and 100%. To give an idea of what I've used just based on visual impression, for a dmax of 1.68 I use 1.53 for 95%. If the dmax is 2.40 (like some glossy papers) I use 1.95 as the 95% point. The eye really has trouble seeing into those very dark blacks in any kind of "normal" light level. To be really consistent, I suppose I would have to determine what that "normal" light level is. As a practical matter, I make judgments based on how things look in my office. Hope this helps. Paul www.PaulRoark.com
2004-03-06 by Robert Behr
Paul, Helps very much. Thanks
Sent: Friday, March 05, 2004 6:45 PM
Bob,
Hope this helps.
Yahoo! Groups Links
