Howto generate a B/W test strip
2004-03-03 by kcongdon
Does anyone have any pointers for generating a test strip for printing in Photoshop? Are there any actions floating around for this?
2004-03-03 by Paul D. DeRocco
> From: kcongdon [mailto:kurt@...] > > Does anyone have any pointers for generating a test strip for > printing in Photoshop? Are there any actions floating around for this? You mean a step wedge? I put one in http://www.pbase.com/pderocco/test_images. (The zebra step wedge, by the way, is useful for measuring with an Eye-One.) -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
2004-03-03 by Martin Wesley
> -----Original Message----- > From: kcongdon [mailto:kurt@...] > Sent: Tuesday, March 02, 2004 8:48 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] Howto generate a B/W test strip > > > Does anyone have any pointers for generating a test strip for > printing in Photoshop? Are there any actions floating around for this? > Kcongdon, While you could create your own file, you can find several test strips or wedges in the Files section of the group home page in folder: Files > Image Processing The most used being the 21-step. There are also a couple of 100 step wedges and Tyler's Z's which can be very useful in locating trouble spots on the tone ramp. Martin Wesley www.carolynfrayn.com/Guests/MartinWesley/pages/MW_01.html www.borderless-photos.de/guests.html
2004-03-03 by frankg_photo
> Does anyone have any pointers for generating a test strip for > printing in Photoshop? Are there any actions floating around for this? There is/was a PS plug-in called 'test strip' by vivid details which may suit your purpose - I just tried to get a link for you but didn't find it ?
2004-03-03 by Bob Frost
Kurt, Create a new file in Photoshop of whatever size you want - 8x1 inch or whatever. Select the gradient tool and drag it from one end to the other of the new file. If you have got the correct type of gradient (black to white) selected (look at top) you will get a black to white gradient. Then go to Image/Adjust/posterize and select how many steps you want. Hey presto, one test strip. Bob Frost. ----- Original Message ----- From: "kcongdon" <kurt@...> Does anyone have any pointers for generating a test strip for printing in Photoshop? Are there any actions floating around for this?
2004-03-04 by kcongdon
Hi, Coming from a traditional darkroom background, what I had in mind was more of an exposure test strip than a step wedge. I'd like to see what effect varying the print density in varying degrees might have on a printed b/w image. Kurt --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D. DeRocco" <pderocco@i...> wrote: > > From: kcongdon [mailto:kurt@c...] > > > > Does anyone have any pointers for generating a test strip for > > printing in Photoshop? Are there any actions floating around for this? > > You mean a step wedge? I put one in > http://www.pbase.com/pderocco/test_images. (The zebra step wedge, by the
> way, is useful for measuring with an Eye-One.) > > -- > > Ciao, Paul D. DeRocco > Paul mailto:pderocco@i...
2004-03-04 by Paul D. DeRocco
> From: kcongdon [mailto:kurt@...] > > Coming from a traditional darkroom background, what I had in mind was > more of an exposure test strip than a step wedge. I'd like to see > what effect varying the print density in varying degrees might have > on a printed b/w image. A step wedge will do that just fine. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
Ok. So, to do this, would I create a new layer containing the step wedge? What blending mode would I use to blend the step wedge with the test image? --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D.
> > A step wedge will do that just fine. > > -- > > Ciao, Paul D. DeRocco > Paul mailto:pderocco@i...
2004-03-04 by adounoucos@aol.com
Kurt, If you mean a test strip as we used in the darkroom, I do the following: 1-Duplicate the image. Adjust it lighter or darker with curves. 2-Crop the image to a strip that covers the area of interest. Rename it as "name-strip" 3-Print the strip. Readjust, crop and print again. 4-I use Bowhaus Ink Jet Control which allows changes to lightness and contrast at the printing stage and is faster than working with a new duplicate image each time. This method saves a lot of paper and nails the exact look the print will have when done full size. You can cook the strip for 10 seconds or so in a microwave to get the dry down effect. I find it very hard to get a print to look exactly like the monitor or all the reasons of a monitor is not a reflective surface, calibration etc. It also has the advantage of printing the variations close together on one 8x10 sheet for accurate comparisons under the viewing light. Cheers, Angelo [Non-text portions of this message have been removed]
> From: kcongdon [mailto:kurt@...] > > Ok. So, to do this, would I create a new layer containing the step > wedge? What blending mode would I use to blend the step wedge with > the test image? I think I'm starting to get what you're driving at. You want to print a test image with various parts of it "exposed" differently, to see how they all come out? I suppose you could do that, but remember, in digital you don't just have one exposure time variable, you have an infinite range of possibilities through curve adjustment. The most generally useful "brightness" adjustment is a gamma-like curve created by dragging the midpoint of the Curves dialog up or down, but this isn't the same as an exposure variation in an enlarger. If you want to try out a bunch of such curves in a single print, I suppose you could create a number of adjustment layers, each with a different curve, and fill each layer with "black" to disable it, except for square "white" patches that are in different positions for each layer. You could build this set of layers once, save it in a .psd file, and then insert various image layers underneath the adjustment layers. However, the kinds of tweaks you need to do to improve a particular image usually involve specific parts of the dynamic range (e.g., darkening the blacks or bringing out shadow detail), rather than the whole range. When I polish a B&W image, I usually wind up appying a fairly odd-shaped curve, of the sort that one could never get away with in a color image, and one that is tailored to that image. So I don't think a strip that merely "exposed" the test image by varying amounts would be that helpful. I think the better approach is to try to improve your tools for better screen-print matching. Then you won't have to experiment so much. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
2004-03-05 by kcongdon
Thats a good point about curves. I'm loving the control Photoshop affords, but I don't think it's completely sunk in yet. I still find myself falling back to old ways. For example, I still find it easier to judge an image by it's printed output, than by looking at it on the monitor. I'm sure that will change as I spend more time with Photoshop and become more comfortable working in digital. Regarding tweaking curves for black and white, do you know of any good books that address this control in terms of b/w prints? There are loads of good photoshop photography books out there, but I've yet to find one that focuses on using photoshop for strictly b/w output. They all seem to be focused on color, and treat b/w as an afterthought. Thanks for the feedback, it's been very informative! --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D. DeRocco > \I suppose you could do that, but remember, in digital you don't > just have one exposure time variable, you have an infinite range of > possibilities through curve adjustment. The most generally useful > "brightness" adjustment is a gamma-like curve created by dragging the > midpoint of the Curves dialog up or down, but this isn't the same as an > exposure variation in an enlarger. > > .... some stuff snipped ... > However, the kinds of tweaks you need to do to improve a particular image > usually involve specific parts of the dynamic range (e.g., darkening the > blacks or bringing out shadow detail), rather than the whole range. When I > polish a B&W image, I usually wind up appying a fairly odd-shaped curve, of > the sort that one could never get away with in a color image, and one that > is tailored to that image. So I don't think a strip that merely "exposed" > the test image by varying amounts would be that helpful. > > I think the better approach is to try to improve your tools for better
> screen-print matching. Then you won't have to experiment so much. > > -- > > Ciao, Paul D. DeRocco > Paul mailto:pderocco@i...
2004-03-05 by Paul D. DeRocco
> From: kcongdon [mailto:kurt@...] > > Regarding tweaking curves for black and white, do you know of any > good books that address this control in terms of b/w prints? There > are loads of good photoshop photography books out there, but I've yet > to find one that focuses on using photoshop for strictly b/w output. > They all seem to be focused on color, and treat b/w as an > afterthought. Not really. I started with color, and have just been experimenting with B&W on my own, sometimes using guidance found here. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
2004-03-05 by Olaf Ringdahl
From: "kcongdon" <kurt@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Wednesday, March 03, 2004 8:59 PM Subject: Re: [Digital BW] Howto generate a B/W test strip Hi, Coming from a traditional darkroom background, what I had in mind was more of an exposure test strip than a step wedge. I'd like to see what effect varying the print density in varying degrees might have on a printed b/w image. Kurt My way is to crop down to just the area I want to include in the test strip, save it separately (Save As) and print just that strip. If I want a 1 inch by 8 inch strip, I can print up to nine of them on a single letter size sheet of paper, experimentally changing tonal adjustment settings between printings. If I don't fill the whole sheet, I save it for future test strips. If you need a strip longer than 11 inches, you'll obviously need a larger sheet of paper but the principle is the same and you can get a lot of test strips on a single 13 x 19 inch sheet of paper. That is currently my way. If someone knows a better or faster way of accomplishing the same thing I would like to hear about it. Olaf Ringdahl
