StudioPrint
StudioPrint
2004-03-01 by agordo55441
I have questions about StudioPrint.  Is any one in this group using
it?  Are there any user groups?  Thanks.
Re: StudioPrint
2004-03-01 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "agordo55441"
You can add me to the mix just to confuse things.
Ask away.
Tyler
StudioPrint
2006-01-03 by joshhackney
Tyler,
I'm considering Studio Print.  Question for you.
My understanding is that SP is used for setting ink limits, partitioning, and linearization, but
an icc profile is still needed for printing.  Is that true?  If yes, do I need their colorGPS
profiling software too?  90% of my work is B&W so I am most curious about that, but what
about for color too.  I already have an i1.  I'm currently running K3.
I don't see on the Ergosoft website that version 12 is released yet, but I heard that it is out.  I
assume that I'll need v12 in order to support the 7800.
Thanks.
Josh
Re: StudioPrint
2006-01-04 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "joshhackney"
<joshhackney@g...> wrote:
> Tyler,
Since you mention using the K#s and a 7800 below, I'd say yes. You
will be working in CMYK mode. If you were using a monochrome inkset,
no, that data path is "two dimensional", just density.
Well, you need some kind of profiler, if not that one. You'll need
custom CMYK profiles, and hopefully a good profiler that will allow
some K generation choices. With the K3s, you want to be able to build
in a very long K with maximum GCR for good B&W work and that ink set.
You'll do great color with StudioPrint as well, you might want
slightly different K generation profiles for color, but would have to
test to see if that lightest K is visible in highlights.
The i1 will work with GPS and pretty much any other good CMYK
profiling app you can get.
Yes, I'm told next week. I hope it's true.
One warning. With a setup like this your life will be consumed. With
all the settings to get right, iterative linearizations, and
profiling, then start over for the nest paper, you will become MIA.
But then the results can be worth it, most of the time...
...I hope...
It's a financial commitment as well.
Tyler
Re: StudioPrint
by the way, I've sort of been talking people out of going the RIP
route lately, it's just such a major commitment. Particularly for an
individual artist.
The deciding line is this, in my opinion-
If you have not run into some limitation that only a RIP can address,
then you probably should not get one.
Tyler
Re: StudioPrint
2006-01-04 by Louis Dina
Josh,
I agree with everything Tyler had to say in both posts (including
getting consumed in the process).
FWIW, there is a new version of SP version 11 available on the Epson
Wide Format forum in case you are interested.  I just saw it.  I don't
know if that is a less expensive way to upgrade to version 12 when it
is released or not.  Here's the link.
http://groups.yahoo.com/group/EpsonWideFormat/?yguid=107489918
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
> individual artist.
> Tyler
Re: StudioPrint
2006-01-04 by Greg
I'm going to add some general notes in here, they do not apply only
to Studio Print, but to most any RIP.
to
With the use of the three black inks, probably 90% of your work could
be done with a single GCR curve. Since the black inks are not
neutral, you will always be getting some color ink to correct for
this. If the black curve is properly designed to work with the
printer and inks, it should be every bit as good as the Epson ABW
output, but with more control since you are setting things like ink
limits. You would also be changing the tone of the image in Photoshop
(or other image editor). But if you find that one prfile does not
work, generating another with a different GCR would be a simple task.
NOTE: Not all profiling applications will correct for OBA in papers!
You may need an i1 UV with many of them. One suggested application
that you normally don't hear about would be Heidelberg Prinect
Profile Toolbox. The biggest "problem" about profiles from that app.
is what it does with out of gamut colors in either of the
colorimetric intents. If you correct the out of gamut colors like you
should be doing, then there are no issues. Most people seem to expect
the profile to just know what the artist wants done to those out of
gamut colors like a couple of applications do. The other thing that
isn't as good as it could be is the black generation. There is no way
to make a custom GCR curve, but the standard curves should work
really well with a three black printer. Cost if this set of tools is
around $2000 directly from Heidelberg. Even the older Printopen 4 (I
own this version) works very well in CMYK mode with a printer that is
properly linearized. You can use either the i1 or the UV cut. With
the use of Colorport (free) from Xrite, you can use a much larger
number of measuring devices including the DTP20 (Pulse) spectro and
the DTP70 spectro.
Re: StudioPrint
> route lately...
I need to amend this. I'm talking of large complex full featured RIPs
like ColorBurst, ErgoSoft, etc., NOT QuadtoneRIP.
I tend to think of QuadtoneRIP as a special driver, though of course
it is technically a RIP.
Anyway, QTR is great, and I hope my previous comments aren't
discouraging to anyone thinking of working with it.
Tyler
Re: StudioPrint
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg"
Greg, I confess to have never worked with a profiling app that
corrects for OBAs, nor do I have the UV version of the i1. I'm pretty
sure my previous Spectro, the Spectrocam, did not have a UV filter either.
And I've never experienced any problem.
On the other hand, since I've never had the option, maybe I don't know
what I'm missing.
By the way, I've heard nothing but good things about PrintOpen, is
that what you use?
Tyler
Re: StudioPrint
2006-01-04 by Greg
papers!
pretty
either.
What version of Profile Maker Pro did you start with? I think back
with version 3 they started to correct automatically for the extra
blue that shows up on papers with lots of OBA (like EEM). It would be
very obvious if the software wasn't helping you out, the yellow cast
is very visible under nearly every lighting condition. If you only
ever use things like Photo Rag or German Etching, those don't have
enough to cause problems. Even Innova Photo Fiba may not cause a huge
problem. But EEM and many of the glossy papers will give you grief
for your color work.
> that what you use?
> Tyler
I really like Printopen, but the out of gamut clipping really puts a
lot of people off. There's a comment waiting to be said about that,
but I'll leave it alone. Even the older Printopen 4 works really
well, at least for CMYK (I don't ever really use the RGB part). I'm
moving to Monaco Profiler 4.8 for the profiling service, not sure
exactly what I'm going to use for my printer yet. The one thing about
Profiler is that I can make a GCR that gives me real world Black Only
printing through my RIP without having to turn off the other inks.
That was a real advantage before I could turn off the inks (old Fiery
RIP). However, Profiler really requires a UV spectro (I now have an
i1UV, and a Pulse UV in addition to my regular i1, almost time for a
sale). Before I bought Profiler, I was going to upgrade to the
Prinect toolbox, Printopen 5 has some really nice new features to
handle OBA, as well as some new graphing features that would come in
handy. It's also ICC v4 for the printer profiles, and finally
supports direct scanning measurement from an i1, I've been using
Colorport to get around that.
The one thing I like the most about Printopen is the quality of the
profiles from the tiny 210 patch target. I can print a small
linearization target on one end of a 8.5x11 sheet, and the 210 target
on the rest. So with three sheets of each sample I can get a good
test print put onto the other 2 sheets. Comes in REAL handy when
doing a large batch of testing. The IT8 and ECI2002 do much better of
course, but it gives you a good enough idea of what to expect when
you put a bunch of time into optimizing a set up.
If you have a measuring device that works with Colorport, drop me an
email and I'll send you a text file to make one of the PO targets.
You measure, and I'll make, then you can compared directly what they
look like with your setup. Colorport works with i1, most Xrite
spectros, and a couple of the other Gretag spectros.
Re: StudioPrint
None, I don't like it. I have had experience with it though, with a
friend, so have made a few profiles with it.
> I think back
I'm not doubting you, but I just haven't seen it, obviously I use a
lot of papers that don't have much bluing, but I've profiled a few
including EEM without problem. This is with ProfilerPro, EyeOne Photo,
and ErgoSoft GPS.
So maybe it's a sftware dependant phenominon?
> ...(I now have an
> sale).
What do you think of the Pulse? I've been suspecting my old Spectrocam
was better than the i1 before it went wonky. Had great software too.
I really apreciate that. Let's wait untill my 9800 gets here, along
with StudioPrint support. Then I'll be knee deep in setup and
profiling for weeks.
Tyler
Re: StudioPrint
2006-01-04 by Greg
Photo,
> and ErgoSoft GPS.
All i1 software is automatic, not sure about the Ergosoft GPS, And
the ProfilerPro, definitely not (PP sits in a box unused!)
> > ...(I now have an
for a
> > sale).
Spectrocam
The Pulse hardware is a little different. I need to work on the patch
size to try and get charts with a higher patch density per page, if
that works I'll probably switch over to it. For now I'm still using
the i1UV. As far as accuracy, it seems to be reasonable with the
biggest difference between i1UV and DTP20UV being the different UV
filter. And so far the support from Xrite has been very good for me.
> Tyler
OK, let me know when you want to give things a try.
Re: StudioPrint
> Photo,
> > and ErgoSoft GPS.
but not if I don't have a UVi1 right?
For RGB perceptual profiles in particular, with measurement from a
good device, PP is great. Consistantly better than gretag, though I
haven't had access to the newest gretag stuff.
Everything is a compromise though, nothing is perfect.
Tyler
Re: StudioPrint
2006-01-04 by Greg
use a
few
> > Photo,
> > > and ErgoSoft GPS.
Nope just the regular i1, they look at the spectral response of the
paper, and then filter it with math. Some argue this is the best
method, others say that filtering at the light source is best. I
haven't decided which is best yet, so I won't claim either is better.
And I should have really said that the Gretag (Match & PMP) are
automatic.
And I'm pretty sure that Profiler Pro doesn't compensate at all since
I think it only uses L*a*b* values, so it doesn't really know what is
going on well enough to compensate properly for the extra blue. It's
been a while but I remember getting some pretty yellow prints on
papers with OBA with PP, but I abandoned it long ago since the CMYK
profile would not work properly with my (at the time) RIP. Never had
the need to try the RGB side of that software.
