QTR and 7600/9600
QTR and 7600/9600
2004-03-01 by kcooper666
Hi
I've only recently got a 9600 for photo printing use and have been
experimenting with some of the 2200 curves.
I found the OFB ones give quite good results with Epson
semi-gloss. Since the printer is to be used for glossy colour as
well, matt black ink is not really an option...
My question is whether there is any way I can use a flatbed
scanner to have a stab at linearisation? My attempts at
borrowing a densitometer have been unsuccessful so far, and
they are not exactly cheap (or plentiful on eBay here in the UK)
I'm happy to do any calculations and have a go!
Would it possibly be easier to scan a step wedge and create a
photoshop acv curve? or does this affect a different area of how
the driver works?
Although happy to experiment ... if anyone has Photo black
curves for any of the following I'd be greatful for the approriate
numbers:
Epson  PGPP(250)
Epson Premium Semigloss Photo Paper (250)
Epson Smooth Fine Art
(why these papers? - rolls of them came with the printer :-))
As an aside to this I was wondering how  Gimp-Print 5 will
benefit the quad side of things, given the significant architectural
changes?
bye for now
Keith Cooper
Re: QTR and 7600/9600
2004-03-02 by Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kcooper666"
<yahoogroups@n...> wrote:
> Hi
> the driver works?
> numbers:
> Epson  PGPP(250)
architectural
> changes?
> bye for now
> Keith Cooper
Keith;
There are some very good profiles provided by Bill Atkinson (free)
on the Epson website, nose around a bit until you find them,
Steve Karafyllakis
2004-03-02 by Roy Harrington
Hi Keith,
I haven't got a lot of experience with glossy papers, but one thing
I noticed was that many are very similar as far as profiles.  So if
you like OFB curves it's quite possible that the same profiles will
give good results on some other papers.
If you have a "good" stepwedge you could use a fladbed scan
of the good wedge and a test wedge.  Then make a correction
curve that gets you close.
Roy
> Hi
> the driver works?
> numbers:
> Epson  PGPP(250)
> changes?
> bye for now
> Keith Cooper
2004-03-02 by kcooper666
(free)
> Steve Karafyllakis
Thanks, I've been using them for some experimenting, they do
give very good B/W  prints as well, but this question was
specifically about QuadToneRIP curves -- I thought it was time I
had a serious look at it. I was using Lyson SG on an 1160 for my
B/W so the 9600 is just a bit of a change ;-)
Keith
(free)
> Steve Karafyllakis
Keith
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy
Harrington" <roy@h...> wrote:
> Hi Keith,
thing
will
> Roy
Thanks for that. The OFB ones are pretty good on the semigloss.
The only real steps visible looks to be 96/97%  and 98/99%  It
looks almost as if the K Boost is coming in a bit late. I'll get
tinkering...
If I create a photoshop curve and name it in the quad curve file,
does it act as well as the linearisation values that are already
there or instead of?
I'm thinking that I've found a use for that Epson Gray balancer
card that came with the printer!
by for now
Keith Cooper
> > Hi Keith,
> thing
> will
> > Roy
> tinkering...
> by for now
> Keith Cooper
You can add an additional correction curve using GRAY_CURVE=
It's applied after the linearization curve so it may be a little more
difficult to see exactly the interaction of the two curves.   But with
minor corrections I think trail and error would be possible.
Another possibility would be to use PS's custom dotgain curves
and print through a soft proof correction.  I haven't tried this but
I think this would work.
Roy
Cheap densitometer
2004-04-02 by stephane_bosman
You can use VueScan and your flatbed to measure densities. In the
preview, hold the CTRL key down while you hoover on the preview image
of the stepwedge. The densities are displayed on the status bar at the
bottom of the widow.
Accuracy is so-so, but definitely better than eye inspection. I used
that as an input to the LINEARIZE in the curve definition and it
improved matters a lot.
Now I am going to the next level with an Eye One :)
Re: Cheap densitometer
2004-04-02 by ccolbertbw
"stephane_bosman"
Actually, that is probably up two levels ;-)  I just recently got an
Eye One and  so far it's been great. For the linearizations, but also for
calibrating the monitor  and scanner.
Next level up from the scanner is probably an X-rite 810.  Not as
good as the  eye-one by any means, but in practice much, much better than
the scanner  (epson 3200) for linearizations.  At less than 20% of the price of
an eye-one (used on ebay) it  is not a bad option.
Costa Colbert
