Help: which is the best way to print B&W with the R800?
2004-03-04 by ibengarmendia
I've been using my EPSON R800 for two weeks, and I'm satistied with its results in color. But when I print B&W (most of the time), the prints are coldish. And I don't think this is the best way. In my opinion all the inks are used, and I don't know if it´s posible to print BO method. If not, does anyone know which would be the best way? Image Print, maybe? Other inks? Thank you, and sorry because of my poor english.
2004-03-04 by edrudolpho
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ibengarmendia" <iban123@h...> wrote: > I've been using my EPSON R800 for two weeks, and I'm satistied with > its results in color. But when I print B&W (most of the time), the > prints are coldish. And I don't think this is the best way. In my > opinion all the inks are used, and I don't know if it´s posible to > print BO method. If not, does anyone know which would be the best way? > > Image Print, maybe? Other inks? Hi... it's true. With the current R800 driver there is no BO printing. I = wrote to ImagePrint some while ago and they said they would not be making their RIP = available for the R800. Perhaps the following post will do you some good. It was sent to me by Car= l Schoefield and contains a post from another forum. If you do have any luck= , let us know :-) Quoted post from "EJS" via Carl Schofield: > > This is for PC,I have no idea about OX?. > > > > The Japanese version of the R800 allows BO printing.The link below > > is where to downlod the PXG900 driver. > > > > It will install in english on an english operating system. > > > > When the install cannot find the PXG900 printer click to stop > > searching and manually select port and continue the installation. > > > > When the driver has finished installing open the printer folder and > > right click on the PXG900 icon and select properties.At the top of > > the screne click on port.Change the PXG900 to the same port as your > > R800. > > > > Now when you wish BO printing use the PXG900 and not the R800. Here is the thread link: http://forums.dpreview.com/forums/read.asp?forum=1003&message=7775952
> Hi... it's true. With the current R800 driver there is no BO printing. I = > wrote to > ImagePrint some while ago and they said they would not be making their RIP = > available > for the R800. > > Perhaps the following post will do you some good. It was sent to me by Car= > l > Schoefield and contains a post from another forum. If you do have any luck= > , let us > know :-) > > Quoted post from "EJS" via Carl Schofield: > > > > This is for PC,I have no idea about OX?. > > > > > > The Japanese version of the R800 allows BO printing.The link below > > > is where to downlod the PXG900 driver. > > > > > > It will install in english on an english operating system. > > > > > > When the install cannot find the PXG900 printer click to stop > > > searching and manually select port and continue the installation. > > > > > > When the driver has finished installing open the printer folder and > > > right click on the PXG900 icon and select properties.At the top of > > > the screne click on port.Change the PXG900 to the same port as your > > > R800. > > > > > > Now when you wish BO printing use the PXG900 and not the R800. > > > Here is the thread link: > > http://forums.dpreview.com/forums/read.asp? forum=1003&message=7775952 Hi, First of all, thanks for your reply. I,ve tried to do it but after installing the software of the PXG900, and printing as black & white, I've realised that the prints are the same. They look coldish too. Have you tried to do this? It won't be the posibility of printing real B&W with the R800? It would be a pity. Regards.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ibengarmendia" <iban123@h...> wrote:> > > Hi, First of all, thanks for your reply. > I,ve tried to do it but after installing the software of the PXG900, > and printing as black & white, I've realised that the prints are the > same. They look coldish too. Have you tried to do this? > It won't be the posibility of printing real B&W with the R800? > It would be a pity. > > Regards. I wasn't able to get the Japanese driver installed on my Mac. However, I've heard reports of PC users successfully installing this driver and getting *great* BO results. Ed
