QTR confusion - 1280 and UT2 inks
2004-03-08 by Ranyart
I am trying to figure our QTR with linux and using the appropriate profiles. I noticed this link on the profile download section of the web site: http://harrington.com/QTR/1280-UT2.sit Should I be using this under linux? Or, as the .sit file would suggest, is this MAC specific? Also, once I get the appropriate curve setup, I noticed that, in the linux KDE print driver, that you can pick one or two curves, then vary the percentages of each curve. If I have, say a neutral curve, should I pick this for curve one, and nothing for curve two, then make the percentage ratio 100/0 ?? Roy has a lot of documentation, and I have followed the .pdf instructions under the files section of this website, but I can't seem to "get my head around" figuring out QTR! Any and all followups appreciated!
