Streaks on PhotoRag using BO
2004-04-06 by wifflebomb
I have developed a BO workflow that looks great on EEM.  I use an
Epson 2200 and the standard inks (hate the Eboni).
I find PhotoRag significantly more beautiful than EEM, but using BO,
I get a streaking problem: especially in the darker areas, there are
repeating strips of lighter density going in the same direction as
the print heads.  This is not a clogged-head problem-- the streaks
are wider and more vague than you'd see in that situation.  It looks
as if you took a 1/2 inch-wide eraser and lightly drew it across the
page again and again, but with varying force each time.
I've tried using different profiles, etc. but always the streaking on
PR.  When I do full-color BW there is no streaking on PR, and when I
use EEM the BO approach works fine.  Anyone else seen this and found
a solution?  Ideally I would like to do all my BO printing on PR.
Thanks.
Re: Streaks on PhotoRag using BO
2004-04-07 by David Styffe
> Thanks.
I ran across some streaks very similar to what you describe a few
months back with my 2200 while printing 80 calendars on InkJetArt's
DuoBrite Matte in black only mode. Drove me nuts for a few hours. In my
quest for printing speed (hey that project was 1,280 11x17 passes
through the printer) I had checked "High Speed"  Printer Settings at
1440 dpi. Interestingly, I was getting away with it until about 3/4 of
the way through the project. After numerous head cleanings and a few
head alignment procedures, I unchecked "High Speed" and the problem
disappeared.
That may, or may not be the culprit in your case, but it was in mine.
David
2004-04-08 by Clayton Jones
Hello Wiffle,
>BO, I get a streaking problem...
>I use EEM the BO approach works fine.  Anyone else seen this and
>found a solution?  Ideally I would like to do all my BO printing on
PR.
Try adjusting the paper thickness lever - this sounds like a problem I
had once and that fixed it.
Clayton
