U2 inks...switching between B&W and Color
2004-04-30 by jeffleeg8
Hi All: I'm strongly considering using the U2 inks in my 1280, but until I get a 2200 (am trying to decided if the product cycle means a new espon soon) for color, I need to continue to print color also on the 1280. I'm not doing enough to use a CS system. Is it feasable to use the U2, use a cleaning cart, and then the standard dye epson prints? Thanks, Jeff
2004-04-30 by Michael Kitei
You won't need a cleaning cart to go from the ut2 inks to Epson. As it's been explained to me, a couple of cleaning cycles will purge the heads. I've gone back and forth a couple of times with no ill effects. Mike
From: "jeffleeg8" <jeff120749@...> Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com Date: Fri, 30 Apr 2004 16:42:32 -0000 To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] U2 inks...switching between B&W and Color Hi All: I'm strongly considering using the U2 inks in my 1280, but until I get a 2200 (am trying to decided if the product cycle means a new espon soon) for color, I need to continue to print color also on the 1280. I'm not doing enough to use a CS system. Is it feasable to use the U2, use a cleaning cart, and then the standard dye epson prints? Thanks, Jeff Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/ To unsubscribe from this group, send an email to: DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Uns ubscribe> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed]
Mike: Thanks, will order them today. Jeff
Michael: Thanks. Jeff
2004-05-01 by mike
I have found switching between UT2 and Epson OEM dye inks in my 1280 to be a lot easier than I thought it would be. I have not found it necessary to use a cleaning cart after switching. I just run a nozzle check and cleaning cycle(s) if needed. Switching from UT2 to color, I usually don't even need a cleaning cycle. Switching from color to UT2 usually requires 1 or 2 cleaning cycles. I've done the "switch-a-roo" about 5 times now. no problems. -Mike jeffleeg8 writes:
