Softproofing mono with EyeOne Match- additional
2004-04-30 by Tyler Boley
This is a slight add-on to the excellent work Carl and Roy did working out how to make Match work with custom charts, and providing files etc.. I make a lot of carefully considered tonal decisions about what precisely happens in very near black, below 95%. It's been a bit of trial and error to get precisely what I want on paper even with softproofing, perhaps part of it is my monitor. Anyway, I thought the soft proof might indicate more acurately how those areas will print if the profile had more sample points in those areas. After starting to simply add a few to Roy's larger chart, I finally threw in the towel and simply made one with all 256 levels, it was actually easier. It does indeed let me predict a bit better how those slight transitions will print, slightly. I doubt if many will need this, and it probably seems like overkill, but it is still far fewer patches to read then your average color chart. This also brings into focus the issue of monitor profiling. I've used three different apps, all with hardware, two even sharing the same hardware, and they all profile the monitor a bit differently. I guess it's naive to think that here, again, there is some standard to calibrate to, very frustrating. Anyway, if anyone is interested, I have the chart and reference file and can have Martin upload them to the list if desired. Tyler
