Re: [Digital BW] Epson 3000 for Piezography -- paper thickness, etc
2004-05-07 by AWStolzing@aol.com
Don't go for Epson 3000. It is a bad printer. Paper feed does not work properly. It is very slow. It is constructed for dyes, not for pigments, so it clogs with pigment inks. [Non-text portions of this message have been removed]
2004-05-07 by sdmey4@aol.com
In a message dated 5/7/2004 9:18:46 AM Pacific Daylight Time, AWStolzing@... writes: > Don't go for Epson 3000. It is a bad printer. Paper feed does not work > properly. It is very slow. It is constructed for dyes, not for pigments, so > it clogs > with pigment inks. > The original poster is using a 1520 So I would say the 3000 is equal to that mechanically. I have used two with Piezography Pigments, Sundance and Piezotones and even MIS color Pigments, no clogging problems at all. I have even left them unsused for 6 months and One cleaning cycle and there ready to go. Others do have clooggging problems but no more than any other printer.I also use the 9000 carts, so 220ml of ink is bigger than the CIS systems people use with a 1280 and such. Hundreds of prints from these carts. I ran hundreds of prints on 310gsm paper before the paper feed begain to skew. The problem with the thick paper is that the image will not print square. 14inches at the top might be 13 7/8 at the bottom. Not noticable until you go to matt the image, then things get wierd. So I would say 225gsm is the limit, So the thinner Photorag or william Turner should be fine. Definately a budget way to produce fine 16x20's. With the Piezography plug in your looking at 1 hour 15 min per print, At the highest quality setting, this is the newer sttting that eliminated banding on most marginal printers. Thats the only reason(slow) I stopped using them. There was a reference on this list to Tyler Boleys 50 Print Seattle display, These where 90% or more done on a 3000. So its capable of A++++ quality. If your patient and don't want to spend much, I don't see much risk unless you must have the thick papers. And for the original poster: Even though the 1520 takes 17inch paper you can only print to 13inches, Not the case on the 3000! It will go 16.25 I believe. Steve M. [Non-text portions of this message have been removed]
2004-05-10 by Glenn Barry
Maybe the printer needs an adjustment for the paper feed. I have a copy of the service manual if you're interested, it gives detailed instructions on all of the adjustments including paper feed and setting the platen gap for correct thickness, which sounds like the issue. Let me know and I can send you a copy if you like. Glenn ----- Original Message ----- From: "Thomas Keesling" <tom.keesling@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, May 10, 2004 12:54 AM Subject: [Digital BW] Epson 3000 for Piezography -- paper thickness, etc > Arthur, > > I've never been able to get the Hahnemuhle 308 to feed properly through my > Epson 3000. I can get it started and it will print, but the image isn't > printed accurately--it prints short in the paper feed dimension and is > sometimes longer on one side than the other. The Crane Museo (225 gsm, I > think) usually does OK, but it's a bit of a challenge as well. The > Hahnemuhle 188 and 196 work just fine. > > As far as AWStolzing@... comments re the 3000. I disagree for the most > part. I've used Mediastreet Generations pigment inks in mine for 2-3 years > without any significant clogging problems. The paper feed mechanism is > somewhat finicky and the newer models are much improved in this regard, but > it's still a great printer for many purposes. > > Tom Keesling > Intelligent Design, Inc. > > > > > > Please visit the Group Homepage to check the Files, and other resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages to keep them short. > - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. > - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. > - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> > Yahoo! Groups Links > > > > > >
