Re: RIPped off
Re: RIPped off
2004-05-14 by claudej1@aol.com
In a message dated 5/14/2004 10:49:43 AM Pacific Daylight Time,
DigitalBlackandWhiteThePrint@yahoogroups.com writes:
> the ripoff is in having to spend $400-$500 to be able to get the printer to
> do what the manufacturer claimed/claims it can do - i.e. print B&W
> On top of which, for Imageprint - while it does, basically, do the job it
> supposed to do fairly well , it is one of the clunkiest and worst designed
> pieces of software out there - especially if you are paying $1500 to $2000
> or more for the "full" version.
> there is no real reason - apart from complacent market dominance - why Epson
> could not produce a printer that actually does this out of the box.
> tim a
Everyone has the option not to buy it or buy another RIP, or go learn to
write C++ code and do it themselves.
Otherwise, one has to look at investment value, with the assumption that
larger prints sell for larger bucks and the market can bear the higher
price.........or maybe they should all cost 2 grand, even for small printers????
I paid $9000 apiece for Kodak 8x10 color dye sub printers 8 years ago and
$5,000 per license for software to run it along with $15,000 for a 1.5 megapixel
camer with moire, noise and crappy color, so I think these Epsons and most
$300 digicams are wonderful and can produce work that puts my investment of 8
years ago to shame. You have nothing to whine about, you should be celebrate
having tools this good and this cheap.
As for your second point, the Epson 4000 DOES do good B&W right out of the
box, so that makes your statment obsolete.
The whining/double standard at play here also has to do with the fact that
all serious amateurs had separate color and B&W darkrooms/processes and would
never dare to print B&W on color papers. Now we can and should be happy about
it.
Claude
Re: RIPped off
2004-05-14 by chipcarterdc
Hang on now.  I have an Epson 4000.  It does produce "good" B&W out of the =
box and in fact produces slightly better B&W out of the box than the 2200 o=
r
the 9600 (I have the 9600 currently and had a 2200).  But the 4000 does not=
produce neutral B&W, nor does it produce non-metamerismic B&W.  The
prints are still warm and still have color shifting in different light.  So=
, I'm not
contesting that the 4000 is a bit better in this regard, but from my experi=
ence, it
wouldn't be accurate for anyone to see the 4000 as a vast improvement for B=
W.  For exhibition or sale quality B&W, I would not be satisfied w. the 400=
0's
performance out of the box.
I don't want to over-lawyer this, but let's look at what Epson says regardi=
ng the
4000 and B&W (taken from their website):
*	Significantly improves the printer's gray balance while eliminating color=
casts
Incorrect.  "Eliminates" is an objective standard meaning that something no=
longer exists.  Untrue -- there is still a clearly noticeable color cast.
*	Dramatically improves the midtones and highlights for smoother transition=
s
Maybe.  No comment on this one.
*	Enhances the ICC profiling process for ColorSync™ and ICM™ workflows
Uh, OK, I'll give them this one, since it's so vague that it doesn't mean
anything.
*Professional Level Black & White Photographic Printing
Incorrect again.  I suppose I'd have to convene an expert panel, but the
proliferation of 3rd pty inks and RIPs is sufficient evidence that the nati=
ve B&W
is not "professional level."  Otherwise, why would all of these professiona=
ls be
spending thousands of extra dollars.  I do not know of and have not read a =
statement by a single professional photographer who produces exhibition or =
sale B&W just using the native Epson driver and ultrachrome inks (with the =
possible exceptions of Greg Gorman and Vincent Versace (paid Epson
spokespersons) who I bet, if you sat them down in a room, would admit that =
they have reservations regarding B&W out of the box w. ultrachrome printers=
*	Produces a truly consistent image with little color crossover or colorcas=
ts
Please.  I assume I don't need to detail why this is untrue or at least
misleading.  I guess "little" is relative, so yes, compared to say a printi=
ng
method that produces a lime green color cast for B&W, this statement could =
be objectively true.  And I'll admit that B&W is "consistent" in that you
consistently get non-neutral metamerismic prints using the native driver.
*	Reduced metamerism on 7-color black & white& prints
Reduced compared to what?  The 2200/7600/9600?  Perhaps slightly, if
measured with an electron microscope, so this statement could be seen as
literally true.  But still misleading.
*	Depending upon media, produces a black D-max up to 2.1
OK.
*	Produces sellable quality neutral or toned black and white prints
Nope, unless you're selling to someone who's colorblind or likes color shif=
ting
in different lighting conditions.  And "neutral" is a word with an objectiv=
e
connotation not based solely on subjective perception, and it's clear that =
B&W
w. the 4000 (and the other ultrachrome printers) is not objectively neutral=
Re: RIPped off
I have no idea why the formatting is all whacked out on my last message.
Sorry.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chipcarterdc" <
chipcarterdc@h...> wrote:
> > As for your second point, the Epson 4000 DOES do good B&W right out of =
> the
the =
> box and in fact produces slightly better B&W out of the box than the 2200=
 o=
> r
not=
> prints are still warm and still have color shifting in different light.  =
So=
> , I'm not
> contesting that the 4000 is a bit better in this regard, but from my expe=
ri=
> ence, it
> wouldn't be accurate for anyone to see the 4000 as a vast improvement for=
B=
> W.  For exhibition or sale quality B&W, I would not be satisfied w. the 4=
00=
> 0's
> I don't want to over-lawyer this, but let's look at what Epson says regar=
di=
> ng the
> *	Significantly improves the printer's gray balance while eliminating col=
or=
> casts
> Incorrect.  "Eliminates" is an objective standard meaning that something =
no=
> longer exists.  Untrue -- there is still a clearly noticeable color cast.=
transition=
> s
> Uh, OK, I'll give them this one, since it's so vague that it doesn't mean=
> anything.
> Incorrect again.  I suppose I'd have to convene an expert panel, but the =
> proliferation of 3rd pty inks and RIPs is sufficient evidence that the na=
ti=
> ve B&W
> is not "professional level."  Otherwise, why would all of these professio=
na=
> ls be
> spending thousands of extra dollars.  I do not know of and have not read =
a =
or =
> sale B&W just using the native Epson driver and ultrachrome inks (with th=
e
> spokespersons) who I bet, if you sat them down in a room, would admit tha=
t
printers=
> *	Produces a truly consistent image with little color crossover or colorc=
as=
> ts
> misleading.  I guess "little" is relative, so yes, compared to say a prin=
ti=
> ng
> method that produces a lime green color cast for B&W, this statement coul=
d
> be objectively true.  And I'll admit that B&W is "consistent" in that you=
> consistently get non-neutral metamerismic prints using the native driver.=
> measured with an electron microscope, so this statement could be seen as =
> OK.
> Nope, unless you're selling to someone who's colorblind or likes color sh=
if=
> ting
> in different lighting conditions.  And "neutral" is a word with an object=
iv=
> e
> connotation not based solely on subjective perception, and it's clear tha=
t =
> B&W
> w. the 4000 (and the other ultrachrome printers) is not objectively neutr=
al=
Re: RIPped off
Well, putting aside the profanity and unnecessary agressiveness in
your post, I'll respond by saying that I'm certainly no Andrew Rodney
(nor perhaps not even the mighty Scott Graham) when it comes to Epson
printers, color management, etc.  But I have been at this for quite a
while now, having bought the 2200 when it first came out and having
worked with Photoshop since the early 1990s.  And I stand by my
original statement: the 4000 does not produce neutral or non-
metamerismic B&W out of the box, nor have I read ANY review that says
it does (see the reviews at both Photo-i and Luminous Landscape as
well as endless posts by people who have a 4000).  I don't know how
you can say otherwise.  Do you even have a 4000?  Perhaps you could
explain your findings for the benefit of those of us who don't know
what the hell we are doing.
Besides, the point of my post and others was that it does not produce
neutral, non-metamerismic B&W OUT OF THE BOX, which implies that one
doesn't have a degree in color management.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Graham"
<gebilwil@n...> wrote:
> Then you don't know what the hell you are doing.
> Scott
The
light.  So=
> > , I'm not
my experi=
> > ence, it
improvement for B=
Re: RIPped off
I retract part of my statement: I see from your other thread that you
do indeed have a 4000 (and a problem with agression).  I'll further
add that I am quite familiar with the "printer color management/color
controls" method of printing B&W, having used it for almost 2 years
with the 2200.  I'll also add a tidbit for consideration:
(1) From Photo-i's review: "There is no doubt that the Gray Balancer
has added something to the b/w pictures, I managed to remove the
slight warm cast and produce a near neutral print - I say near
neutral to cover myself, but all said and done the prints are about
as neutral as I would want."
Note that he said WITH the gray balancer, he gets a NEAR neutral
print.  The gray balancer is not an out of the box solution for North
Americans, since Epson won't let you have it, and it doesn't run on
OS X (for those of us using Macs).
Rodney
Epson
a
says
produce
one
> > Scott
> > --- In
> The
different
> light.  So=
> > > , I'm not
from
> my experi=
> > > ence, it
> improvement for B=
