HP 7960 vs C84 With EZ
2004-05-28 by sl91911
Has anybody done a comparison of these two approaches ?
The 7960s are going for much lower price now (but ink is $$).
Stuart2004-05-28 by Paul Roark
Stuart,
>Has anybody done a comparison of these two approaches?
On 4/14 I posted a summary of my latest fade test, which included the HP
dyes as well as UltraTone pigments on various papers. I did not run the
tests to a 30% fade end point, but the rates of initial fade tell me the
relevant rates of fade. Presumably those that show no measurable fade had
some and will fade, but at a much lower rate.
Here are the most relevant sections of that post:
My initial conclusions are that the dyes on the latest papers are not bad,
but they are not in the same league with the best pigment-paper
combinations. The new Kodak paper does not appear to be a “breakthrough.”
HP dye on HP paper:
Cyan Mag. Yellow Visual density
50% patch start: .80 .79 .76 .79
600 Hr: .78 .76- .72 .77
100% patch start: 2.06+ 2.05+ 2.03 2.05-
600 Hr: 1.97 1.95 1.92 1.95
MIS Ultra Tone inks on various papers:
Epson UltraSmooth:
50% patch start: .59 .59 .60 .59
600 Hr: .59 .59 .60 .59
100% patch start: 1.61 1.62 1.64 1.61+
600 Hr: 1.60 1.61 1.63 1.61
Epson Premium Semigloss with PremierArt spray:
50% patch start: .58 .57 .58 .58
600 Hr: .58 .57 .58 .58
100% patch start: 2.07- 2.09 2.09- 2.08
600 Hr: 2.05 2.07 2.06 2.06
Epson Enhanced Matte with UT neutral curve:
50% patch start: .61 .62 .62 .61
600 Hr: .61 .61 .63 .61
100% patch start: 1.65 1.66 1.68 1.66
600 Hr: 1.66 1.67 1.69 1.66
www.PaulRoark.com2004-05-28 by sl91911
Paul,
Thank you so much for taking the time to reply.
1. What about the black and white 7960 prints, done I believe with the
#59 cartridge ?
2. I am also curious about the "look" of the prints from the C84 with
EZ vs the 7960. What is your feeling ?
Stuart
<paul.roark@v...> wrote:
> Stuart,
fade had
not bad,
"breakthrough."> > ... > > HP dye on HP paper: > > Cyan Mag. Yellow Visual density > > 50% patch start: .80 .79 .76 .79 > 600 Hr: .78 .76- .72 .77 > > 100% patch start: 2.06+ 2.05+ 2.03 2.05- > 600 Hr: 1.97 1.95 1.92 1.95 > > MIS Ultra Tone inks on various papers: > > > Epson UltraSmooth: > > Cyan Mag. Yellow Visual density > > 50% patch start: .59 .59 .60 .59 > 600 Hr: .59 .59 .60 .59 > > 100% patch start: 1.61 1.62 1.64 1.61+ > 600 Hr: 1.60 1.61 1.63 1.61 > > > Epson Premium Semigloss with PremierArt spray: > > Cyan Mag. Yellow Visual density > > 50% patch start: .58 .57 .58 .58 > 600 Hr: .58 .57 .58 .58 > > 100% patch start: 2.07- 2.09 2.09- 2.08 > 600 Hr: 2.05 2.07 2.06 2.06 > > > Epson Enhanced Matte with UT neutral curve: > > Cyan Mag. Yellow Visual density > > 50% patch start: .61 .62 .62 .61 > 600 Hr: .61 .61 .63 .61 > > 100% patch start: 1.65 1.66 1.68 1.66 > 600 Hr: 1.66 1.67 1.69 1.66 > > Paul > www.PaulRoark.com
2004-05-29 by Paul Roark
Stuart, >1. What about the black and white 7960 prints, done I believe with the >#59 cartridge ? That's what was tested, below. >2. I am also curious about the "look" of the prints from the C84 with >EZ vs the 7960. What is your feeling? That is so subjective I'm reluctant to say anything. In general, I think dyes do have an advantage in making high-gloss prints. Pigments have the clear advantage with respect to flexibility of paper type, including most specifically archival cotton papers. The HP has more metamerism, but I don't find it objectionable. The HP output is quite cool, colder than the EZ neutral on most papers. (I don't know if there are other hues of HP dyes available.) The EZ system allows flexibility here by putting in different combinations of neutral and warm inks, and on one of the really cold matte papers it would probably be cooler than the HP. Under a loupe the HP output has smaller dots than the C84, but the HP samples I have also show very slight microbanding. I suspect the amount of microbanding is more a question of the particular printer than the systems overall. Both should look excellent in normal viewing. My goal with the C82 & C82 was to get a B&W printing system out there that would allow people (especially my wife's genealogy society colleagues) to easily and cheaply make archival copies of their old family photos and snapshots of their kids that would have a very high probability of not fading or otherwise deteriorating in many generations. I think for an affordable and easy "carbon on cotton" archival printer, it is unmatched. Paul www.PaulRoark.com _____________________________________ --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote: > Stuart, > > >Has anybody done a comparison of these two approaches? > > > On 4/14 I posted a summary of my latest fade test, which included the HP > dyes as well as UltraTone pigments on various papers. I did not run the > tests to a 30% fade end point, but the rates of initial fade tell me the > relevant rates of fade. Presumably those that show no measurable fade had > some and will fade, but at a much lower rate. > > Here are the most relevant sections of that post: > > My initial conclusions are that the dyes on the latest papers are not bad, > but they are not in the same league with the best pigment-paper > combinations. The new Kodak paper does not appear to be a "breakthrough." > > ... > > HP dye on HP paper: > > Cyan Mag. Yellow Visual density > > 50% patch start: .80 .79 .76 .79 > 600 Hr: .78 .76- .72 .77 > > 100% patch start: 2.06+ 2.05+ 2.03 2.05- > 600 Hr: 1.97 1.95 1.92 1.95 > > MIS Ultra Tone inks on various papers: > > > Epson UltraSmooth: > > Cyan Mag. Yellow Visual density > > 50% patch start: .59 .59 .60 .59 > 600 Hr: .59 .59 .60 .59 > > 100% patch start: 1.61 1.62 1.64 1.61+ > 600 Hr: 1.60 1.61 1.63 1.61 > > > Epson Premium Semigloss with PremierArt spray: > > Cyan Mag. Yellow Visual density > > 50% patch start: .58 .57 .58 .58 > 600 Hr: .58 .57 .58 .58 > > 100% patch start: 2.07- 2.09 2.09- 2.08 > 600 Hr: 2.05 2.07 2.06 2.06 > > > Epson Enhanced Matte with UT neutral curve: > > Cyan Mag. Yellow Visual density > > 50% patch start: .61 .62 .62 .61 > 600 Hr: .61 .61 .63 .61 > > 100% patch start: 1.65 1.66 1.68 1.66 > 600 Hr: 1.66 1.67 1.69 1.66 > > Paul > www.PaulRoark.com Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
