Paul,
Many thanks. This is now clear. Can't wait to get the inks :)
Best regards,
Stéphane
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roa=
rk@v...>
wrote:
> Stéphane,
> >" With 2 dark grays, the dmax is about 5% less than the Photo K."
> >What do you mean, 2 dark greys?
> The UT2 inkset does not use a light cool toner. Rather, it has dark and
> lighter cool inks that are about the same density as the warm grays. In
> fact, the cool gray is a bit darker than the warm gray. To get the best
> dmax both of these inks are pulled to essentially full on. The yellow
> position ink is turned off. So, the black is a combination of the warm a=
nd
> cool dark gray inks. Not only does this give a better dmax than either o=
ne
> of the gray inks, but is also allows tone control of even the black. As
> such, I prefer a cool 100% black. It seems even deeper than the warm bla=
ck.
> By the way, the Ilford Smooth Pearl is, in my opinion, about the best
> looking glossy paper there is, especially when sprayed with PremierArt Pr=
int
> Shield or Lyson Print Guard.
> Paul
> www.PaulRoark.com
> For UT2 & UT7 information, curves, and settings see:
> http://home1.gte.net/res09aij/
> ___________________________
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.r=
oa=
> rk@v...>
> wrote:
> > >The problem is the 1290 has only 6 ink positions, so it is not possibl=
e =
> to
> > >have the full UT2 set with both Photo Black and Ebony Black, as is pos=
si=
> ble
> > >in 2100.
> > The 1280 and 1290 with the standard UT2 setup can print on glossy or ma=
tt=
> e
> > paper when Eboni is installed. With 2 dark grays, the dmax is about 5%=
l=
> ess
> > than the Photo K. So, I don't think the Photo k is worth messing with.=
> On
> > a paper like Ilford, with its great dmax, you'll probably never see the=
> > difference.
> > > My idea would be to use only the blue toner, not the light blue, ...
> > >Is full tonality control possible with only the blue toner? Or would t=
he=
> > >light blue be a better option?
> > The UT2 cool gray inks are not the ones to use for this. Use the singl=
e =
> UT1
> > toner (M position in hextones, Y position in UT1 quadtones). On glossy=
> > paper up close, you might see some dots.
> > I think Roy uses a one-toner setup on his 7500 and gets very good resul=
ts=
> on
> > matte paper.
> > Good luck.
> > Paul
> > www.PaulRoark.com
> Please visit the Group Homepage to check the Files, and other resources a=
s
> unsubscribe, please edit your Membership preferences by visiting this sam=
e
> page.
> - As threads develop, trim off excess portions of earlier messages to kee=
p
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from=
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner =
and
> Moderators. See "Group Topic, Rules and Guidelines" in the Files section:=
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO =
YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY=
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF TH=
E
> POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILIT=
Y
> TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO=
OR
> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF =
ANY
> THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
