Anyone using preloaded MIS 1280 UT2 inks??
2004-07-12 by Jeff Magidson
Hi fellow listers;
I have been using MIS UT2 inks in my Epson 1280 for a while and love
the prints I can make with these inks, however I am having one MAJOR
problem in using the inks in MIS loaded cartridges.
I have noticed that when I go to install a new cartridge and peel the
tape off of the vent holes, I get a very noticeable sucking sound ( a
lot more than with OEM carts ). I also notice ink that has been sucked
up out of the vent holes. I think this is creating lots of air /
bubbles inside the cartridge chambers. I then get many BAD nozzle
checks. Since air bubbles are causing the problem rather than clogs,
cleaning cycles do not help. The only solution I have been able to find
is to wait 1-3 days  for the bubbles to dissipate and then I get a good
nozzle check. But waiting severals days every time I need to change a
cartridge is not a really good option. Sometime you just want to make a
print! I don't want to go with a CIS because I sometimes go for long
periods without printing.
Is anyone else having this problem? Is MIS doing something wrong on
their end with the filling process to cause this problem?
On a more positive note... once I do get a good nozzle check I have no
further problems. I have left my printer idle for 3 weeks. When turing
it back on after this prolonged period I almost always get a good
nozzle check.
Thanks in advance for your thoughts!
-Jeff
