Re: [Digital BW] Digest Number 2361
2004-07-14 by Jim Harris
AUTOMATIC RESPONSE - I'M OUT OF THE OFFICE UNTIL AUGUST 5TH.
I am conducting botanical research in a remote region of arctic Canada until the 5th of August. I will try to check my e-mail when passing through communities with e-mail access, but it may be a few days before I'm able to respond to your message.
Students taking the TV General Biology class: If you need immediate help with questions or concerns about the course, you can contact my grader, Nick, by e-mail at: uv_22@... or by phone at: 801-318-7638. He can answer questions about test and assignment scores, course timeline and deadlines, etc.
Jim Harris
>>> DigitalBlackandWhiteThePrint 07/14/04 14:03 >>>
There are 17 messages in this issue.
Topics in this digest:
1. Re: HP PrintersShow quoted textHide quoted text
From: "Alan Zinn" <lookaround360@panoramacamera.us>
2. increasing ink load in IP (was best paper for B/W)
3. Re: Taking a printer as cargo on an aircraft - unpressurised?
4. Re: Taking a printer as cargo on an aircraft - unpressurised?
5. I'm going with Cone Editions Inks
6. Re: I'm going with Cone Editions Inks
7. Re: I'm going with Cone Editions Inks
8. Re: I'm going with Cone Editions Inks
9. Ansel Adams Exhibit in Myrtle Beach South Carolina
10. Re: Re: I'm going with Cone Editions Inks
11. Re: I'm going with Cone Editions Inks
12. Re: HP Printers
13. Re: Re: I'm going with Cone Editions Inks
14. Re: I'm going with Cone Editions Inks
15. Re: Re: I'm going with Cone Editions Inks
16. Re: Ansel Adams Exhibit in Myrtle Beach South Carolina
17. Re: Ansel Adams Exhibit in Myrtle Beach South Carolina
________________________________________________________________________
Message: 1
Date: Tue, 13 Jul 2004 23:29:11 -0000
Subject: Re: HP Printers
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "D. Hill"
<hill14701@y...> wrote:
> Currently, my local CompUSA has the 7660 refurb's for
> 79.00 (Grand Rapids, Michigan) but it may be a
> national sale.
> The nice thing about these printers is that the print
> head is on the cartridge itself, so if it clogs you
> are not out a printer... I can't quite see what or
> why mine is a refurb (perfect condition, excellent
> prints), but this printer is quite amazing with 6x9
> images.
> Don
> Recovering Epson Addict
> > The 7660 printer itself costs a little over $100,
> > and costs for ink and
> > paper are approximately $1.70 per print (6 x 9"
> > image size).
> > -- Nick
Don or anybody,
Have you tried printing pans with this printer? Does it do "user
size"? I'd like to print long pics on roll paper.
AZ
Message: 2
Date: Wed, 14 Jul 2004 04:30:32 -0000
Subject: increasing ink load in IP (was best paper for B/W)
I've tried the Moab Entrada with mk using the IP profile, and it's
very nice. Now, if I could just load a little more ink on this paper!
How can I tell IP how to do this?
Message: 3
Date: Wed, 14 Jul 2004 08:10:48 -0000
Subject: Re: Taking a printer as cargo on an aircraft - unpressurised?
Alex,
On what is obviously a much shorter flight, I carried an Epson 1160
with a CFS and full bottles attached from Bangkok to Singapore (about
2.5 hours) as checkin luggage without any problems. As long as the
pressure can equilise on both sides of the ink you wont have any
problems - this has to happen even under pressurisation.
As others have mentioned I think you'll find cargo holds *are*
usually pressurised and heated as well - too many items would be
damaged and or too dangerous. When was the last time you ever pick up
checkin luggage and found it was freezing? Where do they usually put
any pets???
have a good trip back to Oz
Craig / Beijing
Message: 4
Date: Wed, 14 Jul 2004 08:22:15 -0000
Alex,
As long as the pressure can equilise on both sides of the ink you
wont have any problems - this even applies under pressurisation.
As Scott mentioned I think you'll find cargo holds *are*
usually pressurised and heated as well - most commercial aircraft are
connected (lifts, walkways etc) between cabin and cargo anyway so
they would have to be pressurised
regards
Craig / Beijing
Message: 5
Date: Wed, 14 Jul 2004 12:22:22 -0000
Subject: I'm going with Cone Editions Inks
I've just ordered my set of Piezography inks from IJM for my Epson 7600 inked
with matt black UC inks, I'm running Studio Print 10 from a Windows XP Pro system
and will have access to a X-rite DTP41. I plan on using Epson Enhanced Matte to learn
on but will move up to some other types as I get my feet wet. Any suggestions as to
what I should do first (other than the obvious) I usually just play around and find my
way in the dark and eventually come up with what I need, but I thought if I ask you
folks I may be able to shorten the time it takes to achieve some successful results.
Thanks I'm looking forward to making some spectacular prints in the future.
Jack Fisher
St. Louis, MO
Message: 6
Date: Wed, 14 Jul 2004 12:43:28 -0000
Subject: Re: I'm going with Cone Editions Inks
IMHO, you have just wasted money. I have spent a year using Cone Piezo inks and have
just replaced them with MIS UT2. Guess what, the same file printed on the same paper
with both inksets are absolutely impossible to tell apart if printed with the same warm
tonality. And UT2 allows me neutral and cool prints, which Piezo does not.
Add to this the suite of unkept promises from Cone, the overpriced useless software and
I'm done with them.
Good luck anyway in your new endeavour :-)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "tigertwous" <jfisher@s...> wrote:
> Jack Fisher
> St. Louis, MO
Message: 7
Date: Wed, 14 Jul 2004 15:06:04 -0000
Stephane:
I was once a Piezo user - I still look at some of the old prints that
I made with the PS PlugIn - they were good.
When they moved to the ICC format I rode along - I could never get a
good print.
I continue to be confused by the Piezo failure and lack of ownership
in the failure. Sometimes I wonder if this is a problem caused by an
artistic approach to technology. Deadlines are presented, missed and
never acknowledged. The idea that each print setup needs to be
taylored with a custom ICC set (this being how they propose to fix
customers like me who could not get their systems working) makes me
wonder if they really know what they are doing. Epson and other
printer vendors spend millions on making sure every printer is
identical. So ... gets the inks indentical and get a good ICC - not
so much magic.
I've switched to the UT2 inks and am happy with the results -
However, I still look at the Piezo prints and want to move back when
Piezo gets back on track.
Perhaps the biggest difference between Piezo and UT2 is the fact that
people are treated as real customers on the UT2 side. Paul has
answered each of my e-mails the same day.
We all know some big vendor will walk in soon and present a viable
B&W solution that we can buy and use as easily as we do color these
days. Untik then the market will stay with the little guy who
provides service.
A ramble ... I feel poorly for the Piezo folks - a good product
spoiled by a lack of understanding of technology and how to do
business. My greatest respects for the UT2 folks - a good product
supported by people who are willing to do anything to make it a
sucess.
AW
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "stephane_bosman"
Piezo inks and have
on the same paper
does not.
> I'm done with them.
Epson 7600 inked
suggestions as to
successful results.
the future.
> > Jack Fisher
> > St. Louis, MO
Message: 8
Date: Wed, 14 Jul 2004 15:18:28 -0000
I am looking at buying an Epson 1280 and I would like to print some of my photos
with the look of the original piezography inks. In reading comments from the various
users of those inks, it is said that the "warm neutral ink with museum black" will give
me that look. Question, will the UT2 inks give that same look?
thanks,
Martin
Message: 9
Date: Wed, 14 Jul 2004 15:33:00 -0000
Subject: Ansel Adams Exhibit in Myrtle Beach South Carolina
Hello All,
I don't know how many of us in this group live near or are planning
to visit Myrtle Beach, SC before the end of October; but there is an
exhibit of 50 of Ansel Adams images on display starting Friday of
this week at Burroughs-Chapin Museum of Art at 3100 South Ocean
Boulevard till October 31 of this year. If you can, please visit and
be inspired by his photographs. I saw them in Atlanta last year and
plan to see this exhibit at least once a week till it leaves. I live
about 2 hours away from there. This is the website for the museum of
art http://www.myrtlebeachartmuseum.org/current_museum_exhibit.htm
Your friend in Photography,
Johnny
Message: 10
Date: Wed, 14 Jul 2004 10:35:29 -0500
Subject: Re: Re: I'm going with Cone Editions Inks
I just researched all the options and went with the piezography inks
with a CIS on a 1280. I love the results, what I didn't do is get into
the ICC stuff. I did a quick set up with QTR and am getting outstanding
prints. I seriously looked at the MIS inks, they are more versatile and
cheaper. I don't need the versatility and I like the way the piezo inks
look enough that I spent the extra bucks.
The customer service at IJM is not the greatest, it takes awhile to get
through to someone, but when I finally did they were helpful.
cort
Cort Anderson
Training Wheels, llc
www.trwheels.com
620-488-2960
620-488-3196 fax
Message: 11
Date: Wed, 14 Jul 2004 15:43:19 -0000
Cort:
What platform (PC/MAC) are you using?
Which Piezo inks are you using?
Note the the hope in my e-mail.
AW
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Cort Anderson
inks
into
outstanding
and
inks
get
> cort
> Cort Anderson
> www.trwheels.com
> 620-488-2960
> 620-488-3196 fax
Message: 12
Date: Wed, 14 Jul 2004 12:07:20 -0000
Max print size with my 7960: 21,6 cm x 35,5 cm.
If anyone knows how to print longer pictures...
> AZ
Message: 13
Date: Wed, 14 Jul 2004 09:14:12 -0700 (PDT)
I just started using the UT2 setup a few weeks ago. The results are absolutely outstanding. Instead of using canned profiles, you can use the curves (provided on www.inksupply.com website) to edjust the tonality of your images. The MIS setup requires a little more effort in the initial setup but Paul Roark is there to help you along the way..just send him an email and he will get back to you.
Either setup is great...a friend of mine uses piezo inks and the results are wonderful as well!
Good luck
Ross
cort
Cort Anderson
www.trwheels.com
620-488-2960
620-488-3196 fax
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See ôGroup Topic, Rules and Guidelinesö in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ôOWNERö AND ôMODERATORSö OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE ôOWNERö AND ôMODERATORSö OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
To visit your group on the web, go to:
Do you Yahoo!?
New and Improved Yahoo! Mail - 100MB free storage!
Message: 14
Date: Wed, 14 Jul 2004 15:50:09 -0000
Believe me, you will get wonderful results from that combo. I can't
imagine going with the UC K ink instead of one of the Cone K inks though.
Make sure you shake those carts every week or so, and try to print a
little something weekly as well to keep the ink from settling in the
lines. A common problem with many inks these days easily avoided.
Tyler
7600 inked
XP Pro system
suggestions as to
around and find my
successful results.
future.
> Jack Fisher
> St. Louis, MO
Message: 15
Date: Wed, 14 Jul 2004 12:00:16 -0500
I agree, I went with piezo because I am a little more interested in
production than experimentation. In my situation I really didn't want a
bunch of options for tone when I print, too tempting to play too much.
I am on a Mac using the warm neutral inks with museum black. I have a
densitometer that I traded a client some work for and that made a big
difference in setting up QTR. I did do two 21 step charts, one with QTR
and one with the ICC before linearizing QTR. The test charts were close
to each other until I did the linearization and then there was a very
noticeable difference.
The CIS from IJM was less than expected and gave me some problems until
I got through to them and now most of those are resolved.
cort
Cort Anderson
www.trwheels.com
620-488-2960
620-488-3196 fax
Message: 16
Date: Wed, 14 Jul 2004 17:13:07 -0000
Subject: Re: Ansel Adams Exhibit in Myrtle Beach South Carolina
I second the motion to seek out this exhibition if possible. I saw it
at our local science museum a couple of years ago. I went back
three times during the week when no one else was there. Not
even any docents. Just me and Ansel ;-). Really something to see.
David H. Gibson's BW exhibition (search under valley house, but the
web pics truly don't do the prints justice) is also unbelievable.
There are clouds and light streams that literally come out of
the plane of the print!
These are always in my mind when I ask myself whether my
quadtone prints are any good.
Costa Colbert
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Johnny Eades"
<jeades1@s...>
wrote:
> Hello All,
an
and
live
of
> Johnny
Message: 17
Date: Wed, 14 Jul 2004 18:00:16 -0000
A great show I saw several years ago at a small Museum in West Texas
(Abilene). As I recall the show contains many vintage prints from
Ansel's early year's, from negatives that were destroyed in a fire;
they are simply beautiful.
<jeades1@s...> wrote:
> Hello All,
an
and
live
of
> Johnny
Yahoo! Groups Links
