MIS UT density
MIS UT density
2004-07-20 by James Haney
After struggling for days to get a better profile for UT inks on
PhotoRag. I think I have discovered that the ink set is only capable of
a 1.34 max density with Eboni Black.
Is this true?
James Haney
Re: [Digital BW] MIS UT density
2004-07-20 by Ernst Dinkla
> Is this true?
> James Haney
I do not trust my Spectrocam at the highest densities but 1.6 D
should be possible based on the SpectroCam readings and a Kodak
greyscale next to it.
Ernst
RE: [Digital BW] MIS UT density
2004-07-20 by Paul Roark
>...UT inks on PhotoRag. I think I have discovered that the ink set
>is only capable of a 1.34 max density with Eboni Black.
I consistently get about 1.7 with Eboni and PhotoRag.  1.34 is about what
the dark gray will be.  The Photo K is almost as weak.
Are you sure you have Eboni there?
Print a dark gray 100% patch and see how it compares.  (Use the curves with
an RGB 100% patch and turn off 2 of the 3 inks by pulling their curves up to
a horizontal line at 255.)
