Medium Format Film Scanners???
2004-07-20 by Randy Rancier
Can any of you offer any other or better recommendations than what I
have concluded below?
I am in the market for a good used scanner that will handle medium
format negs.  My current budget will not allow me the $1000, or so,
for a used or refurbed Coolscan 8000's on eBay; in fact $500 is
currently more than I can spend.  Unless any of you know of some
older medium format film scanner models that can be had cut rate I
will probably invest in a Epson 2450 or 3200 $150 - $300 or so.  I
understand one can get pretty good 11X14's from 2 1/4 negs, I will be
doing mostly 8X10's for a while anyway; and I could scan some of my
old 4X5's to boot.  While I will eventually upgrade to a medium
format film scanner in the future, from what I know, there aren't any
older model medium format film scanners out there; is there???
Was the Coolscan 8000 the first Nikon Scanner that would handle
medium format?
Thanks for everyones input, I respect all of your opinions!
Randy
RE: [Digital BW] Medium Format Film Scanners???
2004-07-20 by Austin Franklin
Hi Randy,
That is the exact scanner I'd recommend for your budget.  I have seen the
results from it, and for the money, it can't be beat.
Austin
Re: [Digital BW] Medium Format Film Scanners???
2004-07-20 by Ernst Dinkla
> medium format?
> Randy
At that budget I would suggest the Epson 4870 and slightly below
it the 3200. Use wet mounting like I have described it at the
Epson 3200 Yahoo list. Pay attention to masking. With some effort
you can get scans that come close to the wet mount scans of the
Nikon 8000.  I was probably the first one who tried to find the
right methods for wet mounting on the 8000 and 3200, others have
followed that method and were surprised by the quality increase.
ICE on the Epson 4870 seems a bit in conflict with large files.
There are threads on that subject in the Epson 4870 Yahoo list.
Get the cheapest deal on the Epsons, skip Silverfast, go for Vuescan.
There was a 4x5 scanner by Nikon but I wouldn't select that one
above a new or refurbished Epson.
Ernst
Re: Medium Format Film Scanners???
2004-07-21 by Jerry Hadam
Randy,
I think Ernst advice about the Epson scanners is sound. I am quite
happy with Silverfast but never could get Vuescan to work well for me.
I have the 2450 and I made several test scans of 35mm and printed to
13x19" just to test and was blown away with how well it did.
The wet mount makes all kinds of sense to me, but not the time to
implement since I got my digital camera.
Jerry
On Tuesday, July 20, 2004, at 07:08  PM,
> Message: 13
>    Date: Tue, 20 Jul 2004 21:07:34 -0000
>    From: "Randy Rancier" <rrancier@...>
> Subject: Medium Format Film Scanners???
> medium format?
> Randy
Jerry Hadam
208-726-3834
208-720-2383
jerry@...
Box 2910
Ketchum, ID 83340
