QTR and Piezography Inks?
2004-07-23 by john dean
Has anyone around here used QTR with Cone carbon inks as
the primary driver, and if so what has been your experience?
Could I just use this driver and order the inks from Cone ( saving
$700.00) or is that a really stupid idea? You may answer privately
if you like at - deanwork@... or here ...
john
Re: [Digital BW] QTR and Piezography Inks?
2004-07-23 by Cort Anderson
I use this combination on a 1280 and it works well, as well or better
than the ICC profiles for me.
cort
Cort Anderson
Training Wheels, llc
www.trwheels.com
620-488-2960
620-488-3196 fax
Re: QTR and Piezography Inks?
2004-07-23 by John Vitollo
Yes used QTR/Piezotone with two 1160s - with Neutral and Warm inks. Excellent output -
better than the Piezotone driver as QTR can be tweaked to place more in on the paper and
has better dither than the Piezotone driver to name a few pluses.
You would have to build your own profiles as I think I remember you'd like to run a 7000
and/or 7600...correct?
John V.
Profiles for QTR and carbon quad inks
Good. I appreciate that info.
What is involved with profiling for a 7000? I usually have my
profiles for color done at Profile City and I do not have McBeth or
any specialized sofware to make custom profiles. Is that
necessary for that approach or is there somewhere to find
generic profiles for such a purpose? How complex was that for
you?
John
