QTR on Windows -- do Linux version profiles transfer?
2004-08-08 by David Wroblewski
Hi Roy, congratulations on the release of the Windows
version of QTR!
I'm running a 2200 with the MIS UT inkset. Last fall I
linearized the existing UT7 profiles for my printer
and got excellent results.
A couple of weeks ago, the HD on my Linux box died, but
I have the profiles backed up. Is it possible to use
them with the Windows version of QTR? If so, where do I
put them?
David Wroblewski
Re: QTR on Windows -- do Linux version profiles transfer?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David
Oops! Make that "the existing UT profiles" (not UT7).
2004-08-09 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David Wroblewski"
> version of QTR!
> put them?
> Thanks,
> David Wroblewski
They transfer just fine.  You need the .quad files from CurveDropBox/Quad2200
Put then into C:\Program Files\QuadToneRIP\quadtone\Quad2200\...
You will have to enter the exact file names into the Print-2200.bat file.
Roy
2004-08-09 by David Wroblewski
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy
2200.bat file.
Excellent news--thanks Roy. I'll try that ASAP.
-david
2004-08-10 by David Wroblewski
> > (...snip...) Is it possible to use Ultratone profiles
> > developed with the Linux version of QTR under the
> > Windows version? If so, where do I put them?
> CurveDropBox/Quad2200. Put them into
> Roy
Roy & all -- just a quick note to confirm that I was able to use
my UT profiles, just as Roy described. I've tested this on
today's newest version as well.
Bravo, Roy!
-David
