page file and print file assignment
2004-08-18 by jarrrush
Bob -
I am on a PC, Windows XP-Home OS. How can I assign the page file and
print file to a separate hard disk? Obviously you need a scratch disk
but how do you assign these files?
Thank you,
J
essage: 6
   Date: Tue, 17 Aug 2004 16:04:55 +0100
Subject: Re: Re: Ideal Windows computer spec
Chris,
Not sure that your image will reside entirely in RAM. Don't forget
that the
PS scratch file is PS's virtual memory; I think you will find that it
swaps
stuff in and out of the scratch disk all the time, just as Windows
does with
its pagefile.
When you click on print, Photoshop has to convert the image file from
your
working space to the printer space (or send it to the printer driver
to do
that). Then the printer driver has to upsample the image to the ppi
that it
works with internally, and then turn it into the CMYK info for
printing dots
of the requisite colors. When that is all done, the resulting file is
sent
(spooled) to the location specified in the Registry (on your system
disk if
you haven't changed it). Then you get back PS for further work. So I
guess
that it is largely processor and RAM dependant, unless you have very
slow
hard disks, or your pagefile, scratch file, and printerspool file are
all on
the same hard disk (when the heads will be whizzing back and forth
between
these). Put at least some of these on separate disks and they can all
be
doing different things at more or less the same time, thus speeding
things
up a lot.
