QTRPC/1280/ut2 first impressions
2004-08-18 by zonepeter
I got QTR up and running last night with my 1280 and UT2 inks. It's easy if you can follow simple directions (a major stumbling block for me). I did some comparisions with Paul's curves. I made a bunch of step wedges on EEM. The curves seem like good matches for Paul's in terms of tone (as in color tone) Then I made some blends. 75% neutal /25% carbon looks like it may be really nice. Of course you can blend the UT2 with curves or with the sliders on the Epson driver, but QTR seems a bit more intuitive. I made a 100 step ramp for each. Each had 100 differentiated steps (in the past, I have had flat spots with my printer using the curves) but to my eye, QTR is a bit more evenly distributed. The curves may give a little better d max, but again, this is eyeball only...no densitometer. It is so close it is hard to be sure. The stepless wedge looks a little smoother with QTR; perhaps the smoothest stepless I have seen. No abrupt transitions. Then I made a print on Photo Rag. It is a landscape with some blank sky, smooth transitions and some very smooth sand. As has been repoerted, QTR prints a bit lighter and lower contast. Nothing a simple adjustment curve won't fix. The sky and sand are very smooth (as they are with the curves). I can't see much difference in the dither patterns. Both are what I would consider so smooth as not to be an issue. That is with a loupe. So what's the bottom line? I was and remain very happy using the Roark curves and I am very impressed with QTR. Will probably use both. The real fun begins when Roy gets the profiling feature up and running for windows users. By the way, has anyone profiled the Peizotone inks for QTR and a 1280? Would like to try them again.
