My thanks to the poeple who posted the unidirectional command for
QTR; that helps but it's still not completely clean. As for the
paper feed compensation, Martin, I tried the slider in
the 'Configuration' box in the driver, is that what you mean? or is
there another way to do that through maintenance mode? I know the
7500 provides much more extensive alignment in maintenance mode, I'm
hoping thta's the case with the 7600 as well. I still haven't found
the service manuals though.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Martin Sluka
<martin.sluka@p...> wrote:
> Have you try the paper feed compensation setup from service menu?
> Martin
> At 01:36 +0000 22.8.2004, Steven Karafyllakis wrote:
> >I seem to have a pronounced dither banding problem on the 7600,
not
> >only with QTR but anyway I try it-except in unidirectional mode.
> >Seems there's a bi-direction problem of some kind that isn't being
> >fixed by simple head alignment. So, a question for Roy, and a
> >general question to anyone who can help:
> >How do you write in the command for unidirectional printing?
> >Where can I get the tech/service manual PDFS for that printer?
> >Thanks
> >Steve Karafyllakis
> >http://www.stevekphoto.com
