Epson 2200 and Roll Paper
2004-08-24 by A. Huntley
Is anyone among the ImagePrint community using roll paper with the Epson 2200 (IP driver, of course.) If so, or anyone else just knows the answers, I'm listening... 1. What is the heaviest weight paper that can be successfully fed through the roll paper feed slot? 2. Do you use the paper cutter attachment? 3. Can the normal feed slot or rear paper slot still be used for single sheets? Assuming, of course, that the roll paper is retracted first. 4. To print, using IP, does one simply uncheck the "Sheet" box? 5. Does IP communicate with the printer for auto paper cutting like the Epson driver? Thank you to all. Regards, Alan Huntley P.S. I'm cross-posting this to the Digital B&W forum, too. [Non-text portions of this message have been removed]
